BigJimnyMeet 2024
Jimny electrical problems
- Mads
- Visitor
15 Dec 2017 09:23 #187476
by Mads
Jimny electrical problems was created by Mads
Good morning,
This is my first post so go gentle with me...
I have a suzuki jimmy with some electrical issues. The heater blower won't work, but the interesting part is when I try to turn it on the main lights goes off, if I turn on the seat heater the lights goes off etc. What could be the issue? bad grounds, or maybe a rele?
Went over the fuses inside the car, only one was blown (to the seat warmer). Is there any more fuses I should check? Engine bay?
Would be great if someone could post some pointers, and maybe pictures of what I should check out
Have a great day!
Have a great day!
- Thank you received: 1763
15 Dec 2017 10:26 #187480
Replied by Lambert on topic Jimny electrical problems
Wierd stuff like that is usually an earthing fault. Wouldn't like to say which one though, a systematic review of them reference to a wiring diagram would be the first step.
The following user(s) said Thank You: Mads
- Mads
- Visitor
15 Dec 2017 13:54 #187483
by Mads
Replied by Mads on topic Jimny electrical problems
Thanks,
OK. Is there any wiring diagrams on this site for the car?
I will go over and check each and single one.
I can hear it click in the rele underneath steering column.
- mickt
- Visitor
15 Dec 2017 19:12 #187498
by mickt
Replied by mickt on topic Jimny electrical problems
If you can hear the relay clicking then maybe the blower fan has seized!
- Mads
- Visitor
16 Dec 2017 08:45 #187520
by Mads
Thanks for the input Mickt,
But when I try to start the fan, or anything else (seat heater) all the lights goes off....
I mean every light, and then won't turn back on before i "shut down" the fan, or turn on the main lights with the switch on the left side.... Very strange thing.. Im giving two cents that it is ground problems.
- Visitor
16 Dec 2017 09:43 #187522
Replied by Daniel30 on topic Jimny electrical problems
Did you have a good look at all the fuses, I had one on another car years ago that had just a hairline crack in it, it wasn't obvious that it had blown
- 1066Boy
- Visitor
16 Dec 2017 18:23 #187549
by 1066Boy
Replied by 1066Boy on topic Jimny electrical problems
Surprised you did not notice the crack when you pulled out the fuses to polish them Dan.
- Visitor
16 Dec 2017 19:17 #187555
Probably done it when I had the dremel polishing pads on the fuse buffing it up
- Mads
- Visitor
18 Dec 2017 14:51 #187597
by Mads
I can't figure this out.
If I turn on the seat heater, try to open / close electric window, fan, or rear window heater the main lights goes off. Apparently the stuff that I'm trying to turn on won't work. Any clues? Pointers?
18 Dec 2017 14:57 #187598
Replied by mlines on topic Jimny electrical problems
Do you mean the switches no longer function or just the switch lights go out
The switches you mention are all common to the main lighting circuit
- Mads
- Visitor
18 Dec 2017 16:01 #187601
by Mads
Thanks milnes.
Maybe I was a little unclear regarding previous post.
They are not functioning on activation, that being said when pressing the switch the lights goes out (main / head lights).
When turning on the head / main lights stays on regarding pressing the switches or not - but the function on the switch won't work. I can see of your diagram that everything is connected to the main light, but should I check ground for each switch? or is it connected to a reley or similar?
19 Dec 2017 15:40 #187621
by Busta
Replied by Busta on topic Jimny electrical problems
Have you wired any accessories into your Jimny? Lights, CB radio etc.
Time to create page: 0.116 seconds
