strange noise /whine at around 50 mph
- treasurer
- Visitor
Over the past year i have started to hear a whinning noise at around 50 mph if you reduce speed the whinning goes if you increase speed the whinning changes note to a higher pitch then goes compleatly when you reach 60 mph .
Lifting the accelerator momentarily seems to have no effect as also coasting in neutral .
It is hard to pinpoint the sound whilst driving but it sounds behind me rather than in front .
Has anybody experianced this or got any ideas of what it could be ?
Thanks
It might give away which it is if one is very low.
- treasurer
- Visitor
The oil in the rear diff i changed late last year and it had a lot of metal fillings in and also stuck to the drain plug .
When i bought the car new it was serviced by the dealler but looking at the state of the rear diff oil i would say it had never been changed .
I am on my second gerbox as the first one ,a bearing collapsed and it ate itself .
I will check the oil levels when the weather improves but from apprevious visual inspection there was no leaks .
This fault does not sound the same as the last time i had geerbox trouble .
The sound perhaps coud be better described as a wah wah sound
Sounds crazy i know .
- vitara_mad
- Visitor
- Skinhead
- Visitor
vitara_mad wrote: have you checked the rear wheel bearings ????
You cant get enough of the rear wheel bearings can you???
- vitara_mad
- Visitor
there my favourate job
- Skinhead
- Visitor
Good cus mine are sat waiting, see you tuesday
- treasurer
- Visitor
- vitara_mad
- Visitor
treasurer wrote: Hi I thought wheelbearings whinned at all speeds not just at one particular speed ?
depends how worn it is & the whining gets louder the faster you go so its worth checking at least
- vitara_mad
- Visitor
did i not tell you im leaving the country for 6 months on monday
- Skinhead
- Visitor
Ill be at your house at 6.00am
- treasurer
- Visitor
but thanks for your input
