BigJimnyMeet 2024
Annoying noise....stumped!!!
- Jimnyadmirer
- Visitor
22 Nov 2012 13:09 #53907
by Jimnyadmirer
Annoying noise....stumped!!! was created by Jimnyadmirer
Hi all,
Well, less than a week into owning my used Jimny, I'm getting this really annoying noise...
It sounds a bit like a metal on metal / grinding / whirring / rotating noise coming from the under side of the car..
It starts at around 30mph (ish) and continues all theway up and down the speedo until I'm almost stopped... Around 10-15mph. It's even still there when clutch is disengaged and its outif gear...
So far ice had all the wheels off.... Scraped all the rust of the backplates and disc edges.... Had the rear drums off and cleaned out all the rust in there too (did find the drivers side rear drum back plate rusted through and thought that might be the cause..... But noise is still there!)
Could it be anything to do with prop shafts etc?
Have had a look on the forums relating to this but so far could only find info on the disc backplates.... Has anyone encountered this problem and rectified it??
Your help is greatly appreciated!!
Thanks
Ian.
Thanks
Ian.
- markyp2000
- Visitor
22 Nov 2012 18:14 - 22 Nov 2012 18:16 #53925
by markyp2000
Replied by markyp2000 on topic Annoying noise....stumped!!!
try looking at the heat sheld on the exhaust near the cat
make shore your in 2wd
Last edit: 22 Nov 2012 18:16 by markyp2000.
- Jimnyadmirer
- Visitor
22 Nov 2012 19:30 #53931
by Jimnyadmirer
Replied by Jimnyadmirer on topic Annoying noise....stumped!!!
Hi markyp,
I've checked the heat shield to see if its loose and it seems pretty solid!!
I'm just beginning to wonder if its a dry bearing or a bearing on the way out?
It's really hard to pinpoint the source!! Driving me round the bend!!
- ZookFastback
- Visitor
22 Nov 2012 20:32 #53936
by ZookFastback
Replied by ZookFastback on topic Annoying noise....stumped!!!
Are your uni joints greasable? Or have you tried spraying into the CV joint on tailshaft?
- Thank you received: 584
22 Nov 2012 20:38 #53939
by facade
Replied by facade on topic Annoying noise....stumped!!!
You could take a risk and jack up both rear wheels, putting the axle on secure axle stands, then drive the car to 40 mph and see if it still makes the noise, then you will know it is in the driveline or rear axle.
(Be careful that it doesn't come off the stands, or a wheel touch the floor, be ready to brake quickly)
Then you could take the bigger risk of getting someone else to "drive" whilst you go around listening for the noise.
(I wouldn't advise getting underneath though)
- Jimnyadmirer
- Visitor
23 Nov 2012 08:20 #53998
by Jimnyadmirer
I'm thinking that might have to be the way forward at the moment... Can't see any other way round it... Dot really want to take it to a garage yet, especially at this time of year etc... Could end up costing a fortune!!
- Jimnyadmirer
- Visitor
23 Nov 2012 08:22 #53999
by Jimnyadmirer
I'm not 100% sure zookfastback, I'm new to the world of jimnys and a very amateur mechanic... Electrician to trade so I'd be alright if I had a problem with the electrics!!! Ha.
- Jimnyadmirer
- Visitor
23 Nov 2012 08:33 #54001
by Jimnyadmirer
- Thank you received: 252
23 Nov 2012 14:12 #54026
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Annoying noise....stumped!!!
Sent you a pm. If you did replace the backplate you would have to do the rear wheel bearings too.
Grey pick up Jimny
- Rob2933
- Visitor
23 Nov 2012 18:36 #54045
by Rob2933
Replied by Rob2933 on topic Annoying noise....stumped!!!
Does it do it in four wheel drive ? I had the same it was the front vac hub leaking putting it in four wheel stop it then back into normal drive it would be ok for a while then start again
- Jimnyadmirer
- Visitor
23 Nov 2012 19:02 #54047
by Jimnyadmirer
J999pre, sent you a PM back.
I had it in 4 wheel drive for awhile today and didn't get up any great speed to try it out to Be honest! Haven't had much of a chance to look into it again today at all.
I did notice however that even at a speed lower than 30mph web I hit a bump in the road it would rear its head for a short while!?
Think it's time to take the wheels off again...
Bought myself a pair of axle stands today... Need to beat this niggle!!!
- Jimnyadmirer
- Visitor
24 Nov 2012 13:22 #54092
by Jimnyadmirer
Right, got the car up on the jack and stands this morning and have found a little something which may point towards the noise??
Found this... Think the seal has gone and it could be running dry of grease? Dirt trapped inside?
Just working out on the street today and its freezing, so might have to wait till next week once I clear some of the rubbish out of my garage!!
Time to create page: 0.127 seconds
