BigJimnyMeet 2024
Jimny Knocking under seats
- 355858
- Visitor
15 Nov 2012 17:07 #53321
by 355858
Jimny Knocking under seats was created by 355858
Hi Guys,
getting a knocking noise at low speed/pulling away in 1st from under the front seats some where, any ideas?
Thanks
Thanks
- Thank you received: 153
15 Nov 2012 17:19 #53324
by supergaz
Replied by supergaz on topic Jimny Knocking under seats
The transferbox is pretty much there, Are the mounts all in good condition?
- Thank you received: 116
15 Nov 2012 20:36 #53366
by maverick
Jalapeño, IISY?
Replied by maverick on topic Jimny Knocking under seats
probably Transfer Case mount gone
either that or you have left a spanner under the seat (lol)
Jalapeño, IISY?
- 355858
- Visitor
01 Jan 2013 13:11 #56773
by 355858
Replied by 355858 on topic Jimny Knocking under seats
Hi guys,
Left it a while before i replied..
Can someone tell me if this would be the problem..
m.flickr.com/photos/benwinkphotography/8333575954/
Thanks
Ben
Thanks
Ben
- Sponnie
- Visitor
01 Jan 2013 15:50 #56787
by Sponnie
Replied by Sponnie on topic Jimny Knocking under seats
Cracked T/box mount. I would have presumed that this now lets the t/box rotate more on its mounts when your setting off, when its under the most torque.
I'm not sure what the knocking is - it could be your t/box gear lever knocking against the body maybe?
01 Jan 2013 18:09 #56808
by supergaz
Worth upgrading to heavy duty mounts from ORA or KAP, or replace with weak originals from Cam.
- trextr7monkey
- Visitor
01 Jan 2013 21:43 #56846
by trextr7monkey
Replied by trextr7monkey on topic Jimny Knocking under seats
Asylum seekers?
- Cautiously reckless rick
- Visitor
01 Jan 2013 22:45 #56860
by Cautiously reckless rick
Replied by Cautiously reckless rick on topic Jimny Knocking under seats
Just check t/box mtg and intemediate prop joints between g/box and t/box have known the prop to cause this on other 4x4s but is usually mtgs.
02 Jan 2013 07:54 #56871
Replied by mlines on topic Jimny Knocking under seats
Check the UJs on the propshafts
- 355858
- Visitor
08 Mar 2013 22:17 #65019
by 355858
Ok, well replaced the transfer box mount drivers side and still doing it, I've noticed that when this sound occurs the 4x4 gear knob is moving (a lot) and sidewards to the point if i pull away fast it nearly touches the seat under the torque i guess. Any ideas??
- markyp2000
- Visitor
08 Mar 2013 22:28 #65020
by markyp2000
Replied by markyp2000 on topic Jimny Knocking under seats
What seat does it nearly touch and have you changed the pasengers side mount
- 355858
- Visitor
09 Mar 2013 07:10 #65030
by 355858
Drivers side, no i havent
Time to create page: 0.120 seconds
