Spot light wiring, help!!!!!!£
- ne-crock
- Visitor
But i'm well and truely fucked!
I cba any more fuck it!
What wire is the wire i need to take a feed from my high beams?
Do i just splice the wire?
Currently working in the rain! They are being wired today!
So help would be fantastic,
Cheers crock
- markyp2000
- Visitor
- Jimnyash
- Visitor
Is that what you're looking for? If so, let me know and I'll see if I can get you info on the cabling.
- ne-crock
- Visitor
But yeah that sounds like what i'm looking for
Thanks
Spending another day at it today!
- ne-crock
- Visitor
I'm presuming the redwire is the wire i need to splice?
Please can someone correct me if i'm wrong
Cheers
Crock
- Jimnyash
- Visitor
I wont have access to the Jim until tonight.
Let me know if it could be of any help.
- p1ngu32
- Visitor
If you were to splice into any red wire on the jimny then anything you plug into there will be on permanently as the power is always on, suzuki decided to put the switches in the negative side of the wiring.
- ne-crock
- Visitor
- Thank you received: 210
I must have posted this about 10 time in the past.
Dirtydogz,.
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
- markyp2000
- Visitor
p1ngu32 wrote: On your relay, pin 86 to 12v. Pin 85 to earth side of your main beam as the jimny is Negative switched. Pin 87 to 12v. and pin 30 to the postive of your lights.
but if you wire a live to the spot light and then the earth to the back of the head light on of the lives goes to an earth but its a bit of a bodge way to do it iv just fited 6 spots on mine run through 3 relays 4 at the front 2 at rear as work lights and soon to be fitting a light in the back running of a pin switch on the rear door but still scratching my head at the mo on how i want to do it
- ne-crock
- Visitor
But anyway its done now
Why does it get dark quickly when you dont want it to but when i do the sun is refusing to set!
2002 JLX Soft Top
