BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
jimny leaning to one side?
  • Madge
  • Visitor
  • Visitor
24 Apr 2012 18:30 #38506 by Madge
jimny leaning to one side? was created by Madge
hi every one i was just wondering if any one could help my jimny is slowly starting to sag down on the left hand side its gt 2inch coil spring lift with rough country shocks and there only a year old everything looks ok apart from the sag was thinking of swapping the right front for the left front to even it out would this work thanks matt
24 Apr 2012 18:44 - 24 Apr 2012 18:45 #38510 by supergaz
This is common, Known as the jimny lean. Most suspension kits have a longer offside front spring to take the extra weight of that corner of the jimny.
The easy fix is to fit 1 spring spacer to that corner.
www.bits4vits.co.uk/store/jimny/spring-s...y-lean-/prod_43.html
I use 4 of these spacers to compensate for the extra weight of my roll cage on top of my +3 lift springs.
Last edit: 24 Apr 2012 18:45 by supergaz.
  • Beano
  • Visitor
  • Visitor
24 Apr 2012 18:53 #38511 by Beano
Replied by Beano on topic Re: jimny leaning to one side?
This is what it looks like :cheer:
Mine was leaning too so i bagged me one of these bad boys from bits4vits and fitted it yesterday. £24 and problem solved!
Beano
  • Madge
  • Visitor
  • Visitor
24 Apr 2012 18:57 #38512 by Madge
Replied by Madge on topic Re: jimny leaning to one side?
hi thanks yer i have a role cage and offroad armoury front winch bumper with winch you think fitting one of these spacers to the front left will work? would i need to get 4 like you have as got all the extra weight thanks matt
  • Beano
  • Visitor
  • Visitor
24 Apr 2012 18:59 #38513 by Beano
Oh, sorry..... :blush:
Technical error! cant submit the attached picture for some reason!
Doh!
  • Beano
  • Visitor
  • Visitor
24 Apr 2012 19:01 #38514 by Beano
Attempt two
24 Apr 2012 19:13 #38519 by supergaz
Madge wrote: hi thanks yer i have a role cage and offroad armoury front winch bumper with winch you think fitting one of these spacers to the front left will work? would i need to get 4 like you have as got all the extra weight thanks matt
You only need 1 to level it, If you use 4 you will only compensate for the sagging of the springs. My offside front spring is longer so my jimny sits level, I just wanted the height after adding ORA bumper, winch, cage ect.
  • suzuki jimny fella
  • Visitor
  • Visitor
24 Apr 2012 19:15 #38522 by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: jimny leaning to one side?
what shocks you got then mate +5 is it B)
24 Apr 2012 19:19 #38526 by supergaz
Got +3 Shocks with +3 springs, so yes it will sit about 4.5" taller with the spacers, but the extra weight will drop it slightly.
I also added a 2" body lift to give me more arch clearance.
  • Visitor
  • Visitor
24 Apr 2012 19:31 #38528 by suzuki jimny fella
you have got 4.5 ORA arms then have you
was going to start a topic about this but will ask now fella
i have got +3" lift and 3" cc arms but if i put them 1.25 spacers in could i get away with putting in cc bushes in
just a thought lol lol
or will it be ok with 3" cc arms :( :( :(
24 Apr 2012 19:36 #38529 by supergaz
I have the 4.5" correction arms from ORA, but you will be fine with the 3" correction arms as your springs will have sagged.
24 Apr 2012 19:54 #38530 by mlines
This doesn't quite sound right.
Jimmy lean is to the drivers side, the right hand side. You say its leaning left??
Sent from my HP Touchpad using Tapatalk 2
Time to create page: 0.138 seconds
Powered by Kunena Forum
