BigJimnyMeet 2024
spot lights
- r_ogilvy
- Visitor
04 Dec 2011 14:04 #27196
by r_ogilvy
spot lights was created by r_ogilvy
im trying to wire spot lights, i have wired them u to the main beam, when i turn the lights of they come on
when i turn the light on (normal lights) they go off then when i put the main beam back on they come on again
- Thank you received: 210
04 Dec 2011 16:21 - 04 Dec 2011 17:04 #27213
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: spot lights
Haven't wired my roof lights up yet, but this is how l will be wiring them.
The trigger is the red wire on the headlight plug.
www.bigjimny.com/index.php?option=com_ku...7&id=15565&Itemid=75
Hope this helps.
Attachment neg2pos.gif not found
Hope this helps.
2002 JLX Soft Top
Last edit: 04 Dec 2011 17:04 by dirtydogz.
The following user(s) said Thank You: r_ogilvy
- r_ogilvy
- Visitor
04 Dec 2011 19:05 - 04 Dec 2011 19:06 #27251
by r_ogilvy
Replied by r_ogilvy on topic Re: spot lights
ideal working. opposite wiring on the jimny had to us the - not +
that was a good 4hr pain in the ass,
thanks dirtydogz
thanks dirtydogz
Last edit: 04 Dec 2011 19:06 by r_ogilvy.
04 Dec 2011 19:33 - 04 Dec 2011 19:35 #27258
by dirtydogz
2002 JLX Soft Top
Your welcome mate glad to help.
You can thank Renard 38 for this.
2002 JLX Soft Top
Last edit: 04 Dec 2011 19:35 by dirtydogz.
- r_ogilvy
- Visitor
04 Dec 2011 19:58 #27261
by r_ogilvy
any other car i played with its been a simple job, rather than switching all the wires about.
thanks renard38
thanks renard38
05 Dec 2011 08:03 - 05 Dec 2011 08:04 #27281
by dirtydogz
2002 JLX Soft Top
Help with this switch and relay set up, if the the trigger is the earth, do l need to run a live feed to the ground on the switch to light it up.
Attachment DSCF1638.JPG not found
Attachment neg2pos_2011-12-05.gif not found
2002 JLX Soft Top
Last edit: 05 Dec 2011 08:04 by dirtydogz.
- r_ogilvy
- Visitor
05 Dec 2011 09:25 #27286
by r_ogilvy
Now that's a good question, I want to wire a switch in, do you want them to come on anytime with the switch or with the main beam but with a option to turn then of?
05 Dec 2011 09:50 #27288
by dirtydogz
2002 JLX Soft Top
With the the main beam with the option to turn them off.
2002 JLX Soft Top
- r_ogilvy
- Visitor
05 Dec 2011 10:18 #27290
by r_ogilvy
Just a on/off switch would do it between the relay an the switch wire for the main beam would do that.
That's what I will do I think,
05 Dec 2011 10:50 #27292
by dirtydogz
2002 JLX Soft Top
Ok mate looks like we are using the same set up.
Thank you.
Baz
Thank you.
Baz
2002 JLX Soft Top
- r_ogilvy
- Visitor
05 Dec 2011 11:12 #27295
by r_ogilvy
What I was thinking aswell the earth triggers the relay then the lights come on.
You could have a switch to light it on its own just by an earth leading to the relay with a switch, I think
05 Dec 2011 11:29 - 05 Dec 2011 11:39 #27297
by dirtydogz
2002 JLX Soft Top
You mean earth the switch to the body of the jimny, will save you using the red wire as a trigger on the light socket.
so they come on even if the light are off
Off to work now so let me know how you get on.
2002 JLX Soft Top
Last edit: 05 Dec 2011 11:39 by dirtydogz.
Time to create page: 0.122 seconds
