Dodgey handling after 3" lift
- Phillingham
- Visitor
- viciouspenguin
- Visitor
mines terrible going round sharp courners, and I definatley need a steering stabiliser. in fact thats the next thing i am fitting and then wheel spacers after that.
it will take you a while to get used to the new 'handling', but once you do you will be more confident with the brick-on-blamange.
EDIT: There is also the possibility that there is something wrong with mine too
- bluejimny
- Visitor
but yes your view sounds right, have you took the ARB off?
- Thank you received: 586
Phillingham wrote: The steering is a bit over sensitive and twitchy, tends to pull you into corners a bit.
Not enough castor angle. Moving the swivel axis back at the top to increase castor angle will increase the self centring action.
- doncarlyon
- Visitor
- Monkey
- Visitor
Yep spot on. The only way you will be able to make it "fell right" is to change the front radius arms to suit the 3" lift and yes a damper will help big time.
- Phillingham
- Visitor
- Phillingham
- Visitor
- Thank you received: 9
A steering dumper will make it fill a lot better ......
My one pass MOT without the ARB, guess I was lucky as he licked the Jimny
Snorkel and plenty of rust to be treated
It will drive with massive body roll compared to normal and without the full castor correction ( bushes will only sort out a 2" lift) the steering will feel different.
I have somply got used to mine and I have no caster correction and have no issues wth it. You just have to drive it according to it's handling characteristics, like any modified and lifted offroader really.
- NickG
- Visitor
but i fitted a ORA stablizer kit and it made the steering heavy and
realy drove like a dog so i pulled it of ( after 30 miles ) much happer
now .
So if any body wants it £££ PM me
- Thank you received: 116
Jalapeño, IISY?
