Gen 4 Tyre Pressure
- Thank you received: 481
The label on the drivers door post says 26psi front and rear. Just checked mine with my digi gauge and they are up to 38psi, surely the dealer couldn't get them that wrong?
I would be interested to see what other peoples tyre pressure are set at from the dealer.
- Max Headroom
- Banned
- Thank you received: 217
After a serious rebuke, they have revised their bad practices
- TaterTot
- Visitor
Also looked at the PDI tick sheet, couldn't see 'Check tyre pressure' on there.
- Thank you received: 14
Soeley wrote: Not having had TPMS before, I thought it it have warned of over inflation. Have deflated them down to 26psi now.
I'm sure I've read that TPMS warn when tyre pressure drops below a certain preset level.
Colin
- Themooingman
- Visitor
Thanks for heads up
- Thank you received: 95
Soeley wrote: Yes, I believe the pressure only has to drop slightly to trigger a warning, but you would think it would also warn of over inflation.
You would need to check the handbook but I think its a relative measurement so if the tyre fitter reset the system with the tyres overinflated its not going to know.
- Dorsetdumpling
- Visitor
You therefore “tell it” what the pressures should be.
The system will then warn if tyre pressures drop below this initial setting beyond a defined margin.
More sophisticated versions will show the actual pressures on the instrument panel display.
- TaterTot
- Visitor
