Wobbly O2
- JivingDaddy
- Visitor
Right, bought the wife an O2 on Thursday and we took it out into the country today and it didn't miss a beat. Although I think I'l buy the CO a sports bra - nearly got knocked out twice!
Anyway, took the dual carriageway home and climbing to 45mph all was fine, then the front started wobbling, reached 50 and all went smooth again. Slowing back down, same thing at 45 and then OK again. I suspect (hope) it's just wheel balancing as the problem is speed specific. Any opinions please?
- Thank you received: 153
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
Also try and find a tyre fitter who actually knows how to balance a wheel! This is often a discussed problem on the forum.
- JivingDaddy
- Visitor
Once again, thanks for the feedback.
There is talk of the Spannish built O2 jimnys suffering this more due to manufacturing tollerence within the hubs, Suzuki's fix was to shim the bearings, but these are a weak point of the jimny, especially when used off road and with larger tyres.
- reaper
- Visitor
- JivingDaddy
- Visitor
I'm on the borders of London & Kent. Bit of a treck to Lancashire, but a great idea. Thanks.
Anyone know a good reliable mechanic locally that I can trust with the wife's O2?
- Jimnyash
- Visitor
Got them from the BigJimny online shop (very quick delivery) and did it within 30 minutes.
Made a big difference.
JivingDaddy wrote: Thanks supergaz & reaper.
Markyp2000 is a mechanic on here down that area, might be worth sending him a message.
- fast forward
- Elite Member
- Thank you received: 7
if you cant go round it go over it ! or vice versa ?
- fast forward
- Elite Member
- Thank you received: 28
The dreaded Jimny death wobble is a most annoying fault that most owners have experienced at sometime and can be difficult to fix.
Not sure JivingDaddy if you know, but all soft tops where built in Spain and the hard tops come form Japan. There is talk of differences in build quality, but I'm not convinced.
I have had wobble on both the Jimny's I have owned. After checking wheel balance; wheel bearings and king pins. Check discs for warp (this fixed my problem in the past).
If you fit bigger tyres and wheel (heavier), this can also make the problem worse.
Shims have also been reported many times as a fix.
If you have checked all the above and still no joy, fitting a steering damper will also help (this worked on my current Jimny).
Good luck and let us know what fixed the problem.
Paul
2005 Jimny VVT soft top
2002 Jimny Soft top - Sold
2007 Triumph Tiger 1050 - Sold
2011 Kawasaki W800
2002 Twin boys
2001 Kerry Blue Terrier - RIP
2012 GoldenDoodle
- reaper
- Visitor
.fast forward wrote: i have the same problem on my 02 54 plate . king pins ! now also needing brake pads and discs so can fit all new at the same time , good job reaper lives round the corner nudge nudge
No problem mate if you need a hand pop round . . . . .and i can show you where sponnie lives
