BigJimnyMeet 2024
driving in snow
- Carrow
- Visitor
25 Jan 2013 21:29 #59574
by Carrow
driving in snow was created by Carrow
Hi, I was driving home from work this evening in bad snow blizzard conditions, drifts across road, I had 4x4 engaged, and was doing great 20MPH, then i drove into an area of deeper snow, say 5 cm, where I slowed down a little with the gears to arround 10MPH(no Brakes applied), and then it happened, the tail end of the jimny was all over the place, I tried steering into the skid but the only way I managed to get back control was slight acceleration. Anyone else had this problem, is it a Jimny problem, or a bad 4x4 driver.
- reaper
- Visitor
25 Jan 2013 21:37 #59578
by reaper
Replied by reaper on topic driving in snow
Your front wheels may not have engaged 4wd correctly
Search the forum there are loads of theads detailing how to check them
- Carrow
- Visitor
25 Jan 2013 21:44 #59580
by Carrow
Replied by Carrow on topic driving in snow
heard the usual click when the hubs locked, and the green 4wd light was lit up on dashboard. Without the 4x4 on, i was just wheel skidding, so I'm pretty sure it was engaged.
- little jimny
- Visitor
25 Jan 2013 21:50 #59581
by little jimny
Replied by little jimny on topic driving in snow
what tyres are you running, and how much tread is on them?
- ne-crock
- Visitor
25 Jan 2013 21:56 #59583
by ne-crock
Replied by ne-crock on topic driving in snow
I find if i gear down in the snow my back end tends to try meet the front, but i'd say i'm alot more agressive than what you described,
say plodding in 4th and dropped to second, this is purposly to kick the back end into a slide for drifting etc, it happens in 4wd but more so in 2wd its great!
enjoy it whilst it here will be gone soon and everyone can go back to driving sensibly
- Carrow
- Visitor
25 Jan 2013 21:57 #59584
by Carrow
Matador izzarda mp71 A/T, tread depth 6mm 'ish
www.matador-tyres.co.uk/products/4x4-tyr...tador-mp-71-izzarda/
- badboy-jimny
- Visitor
25 Jan 2013 22:39 #59592
by badboy-jimny
Replied by badboy-jimny on topic driving in snow
Id say it depends on tyres a fair bit. Plus snow is still snow whatever your driving, all I have done is pushed my jimny to the limit to see where the limits are in the ice and snow. Im with Ne Crock.... enjoy it while its here. I love the snow in my jim
- trevorjd
- Visitor
25 Jan 2013 22:48 - 25 Jan 2013 22:49 #59596
by trevorjd
Replied by trevorjd on topic driving in snow
It's does happen. So it's probably not your driving.i was driving on forestry roads doing a treasure hunt in a hilux last weekend and when your change down sometimes the back end would twitch a bit.....just enjoy it......not so bad after its happened a few times as you come to expect it a bit. The hilux was on road tyres.
Last edit: 25 Jan 2013 22:49 by trevorjd.
- GuardianAngel
- Visitor
25 Jan 2013 23:15 #59609
by GuardianAngel
Replied by GuardianAngel on topic Re: driving in snow
The J is very light and any variation in thickness and density of the snow as the wheels run through will give it the wobbles.
Just take it easy and it will get you through, just enjoy the ride
- Jimny J
- Visitor
26 Jan 2013 00:38 #59627
by Jimny J
Replied by Jimny J on topic driving in snow
Its called lift off over steer. I had the same thing a few times, just gave it a lil bit more throttle and sorted itself out. Well most of the times anyway
Have to say, the fact you can go too and from 4wd whilst moving is quite handy at times!
- Jimny J
- Visitor
26 Jan 2013 00:44 - 26 Jan 2013 00:45 #59629
by Jimny J
Should add if it starts too do it in rwd, dont give it more throttle as it will slide even more! Worst case if your not going to fast is just go for the brakes and hope you dont slide into anything. I had mine completely sideways a few times the other night.
I find in the snow that my steering wheel knob really helped keep the front pulling in the right direction! Can really throw it around.
Last edit: 26 Jan 2013 00:45 by Jimny J.
- Carrow
- Visitor
26 Jan 2013 18:40 #59739
by Carrow
Thanks for all your help, I did have another play in the snow and managed to replicate the problem and a bit of acceleration brought it back, under control, it felt as though the front wheels lost grip.
Time to create page: 0.099 seconds
