BigJimnyMeet 2024
Tip for oil filter removal
- Chilgrove
- Visitor
25 Sep 2011 15:01 #22487
by Chilgrove
Tip for oil filter removal was created by Chilgrove
I am sure many of you will already know this but it may be that some do not so I want to pass on a hint I discovered yesterday. I had bought a Draper chain oil filter removal tool but found the chain just slipped around and was as much use as a chocolate tea cosy.
So, brianwave, how about a piece of sandpaper (could not find any emery) and fold that around the filter to give more grip. I had the rough side to the filter. Still did not work so ultimate brainwave was to fold the sandpaper over so rough side onto both filter and the chain. It worked a treat.
- happypig
- Visitor
25 Sep 2011 15:09 #22490
by happypig
Replied by happypig on topic Re: Tip for oil filter removal
A mate of mine used to advocate banging a nail into it.
- Thank you received: 584
25 Sep 2011 15:32 #22492
by facade
Replied by facade on topic Re: Tip for oil filter removal
It shouldn't be that tight: smear oil on the sealing washer and tighten with one hand on the filter body only.
The book says spin it on and 3/4 turn tighter.
I have knocked a screwdriver though one before to undo it: very messy, and if it hadn't come undone then I would really have been in trouble
25 Sep 2011 15:58 #22494
by mcjimny
Replied by mcjimny on topic Re: Tip for oil filter removal
I've always just knocked a screwdriver through! Everytime i go to the motor factors i say i'll get a proper tool.
Screwdriver method works well on the jimny but not so on the mrs' focus. You can't even see the filter from above, after much swearing and cursing i got it off and looked like i'd rebuilt a whole car
- Northern-Wanderer
- Visitor
25 Sep 2011 18:54 #22528
by Northern-Wanderer
Replied by Northern-Wanderer on topic Re: Tip for oil filter removal
The best way to remove the oil filter is to buy the type with the large nut fabricated on the end & use a socket to remove it,or a filter with "flats"on the end & use the special socket driven tool which fits to remove.They only cost a fiver and save a lot of bother.
- meanbgreen
- Visitor
26 Sep 2011 07:12 #22551
by meanbgreen
Replied by meanbgreen on topic Re: Tip for oil filter removal
ya only have to hand tighten it. That does not mean torque the livin ho ha outta it. As it heats it expands the seal causin it to tighten up more so if ya tighten the piss outta it to begin with it'll be hell gettin off. I can understand if the previous guy did it but when yer in control of puttin yer filter on there is no reason to be that tight. I can take mine off come changin time with just my hand. Alot of folks over tighten oil filters
- goatboy
- Visitor
26 Sep 2011 07:40 #22554
by goatboy
Replied by goatboy on topic Re: Tip for oil filter removal
I have never come across an oil filter I can undo by hand, ever when I have only tightened it by hand in the first place.
I always used the screwdriver punched through method but its nasty if you are doing it underneath or space is tight so I purchased one of these.
www.machinemart.co.uk/shop/product/detai...ench?da=1&TC=SRC-oil filter
Little bit fiddly to use but works reasonably well...
Anyway back on topic, sandpaper is a good tip!
26 Sep 2011 15:03 #22583
by facade
I've got one of those, but I can't make it work
I use the strap and lever type if I have overtightened it and it won't undo by hand.
28 Sep 2011 16:24 #22724
by kirkynut
Replied by kirkynut on topic Re: Tip for oil filter removal
I use the type with the three legs that close in.on it and grip where there is room, such as on a Jimny. You can't lose with those.
- teafortwo0789
- Visitor
28 Sep 2011 17:09 #22729
by teafortwo0789
Replied by teafortwo0789 on topic Re: Tip for oil filter removal
I use a 'Laser Tool' which is like a pair of pliers which grip the filter and being slim will get into most places, also they provide a good feel so you know how much torque you are using.
I've used to use the old screw driver through the filter, too messy but convenient..
I've used a strap which grips the filter and is rotated by using a ratchet, clumsy and won't get into tight places.
Also used a chain with a handle which hooks and tightens, but still slips and not user friendly.
So far the pliers are best for me.
- ZookFastback
- Visitor
28 Sep 2011 17:47 #22734
by ZookFastback
Replied by ZookFastback on topic Re: Tip for oil filter removal
I've always just hand-tightened my filter with a smear of oil and removed it by hand too. The filter is easy to get at and no probs.
- Thank you received: 210
28 Sep 2011 17:52 #22738
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: Tip for oil filter removal
2002 JLX Soft Top
Time to create page: 0.128 seconds
