Pics of a jimny with 2" lift
- Bannerbrother
- Visitor
- doncarlyon
- Visitor
Mines only on the spring spacers so 1 3/4" but the room it made in the rear arches made it look much better and will look even better once i've got some bigger rubber under it too.
- Keefe
- Visitor
- Bannerbrother
- Visitor
- Thank you received: 923
On 205 (standard size) Maxxis Trepadors...
Goes anywhere the "BigJimny's" go -
www.bits4vits.co.uk/store/laning-in-the-...e-dales/blog_96.html
Dave
- Bannerbrother
- Visitor
Did you remove the anti roll bar??
My jimny is non abs and a daily driver with kit would you reccomend? how much of a difference is there compared to standard?
- Thank you received: 210
www.bits4vits.co.uk/store/jimny-gets-a-t...r-lift-/blog_58.html
Hope this helps.
DIRTYDOGZ
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Handles like a normal Jimny*, still zips round as I elected to keep the tyre size stock but went for some knobbly Maxxis Trepadors -
* in my opinion though it just about needs castor correction... I initially lifted the Jimny with Spring Spacers and that handled perfectly, raising it to 2" with the TrailMaster kit and it feels a little "vague"... there's no Jimny "Death" Wobble, it just doesn't quite self-centre properly, and wanders if you run over a cat's eye at speed, etc...
Mine's the ABS model, so I went for the matching kit...
Check out Martin's pricing here in the BigJimny shop, no idea how he can afford to sell them that cheap!
(I offroad a Vitara normally, so the Jimny's mostly my runaround)
- Bannerbrother
- Visitor
Castor correction is just about necessary in my humble opinion... if you're doing it, try it first, drive it and see what you think... I've got used to it, but my missus doesn't like driving it now (hmmm, that's not a bad thing though? ), although I'm sure as soon as it snows again it will disappear again!
Yes, everything else seems fine @ 2", but wait and see what the other experts on here think, I know Vits better than Jimnys... I'm still learning too!
- darthloachie
- Visitor
Jimny-Dave wrote: Goes anywhere the "BigJimny's" go -
what on the end of a tow rope like at Tong?
