- Thank you received: 923
A blummin’ foglight ?!
Bah...
I’ll have to add one just below the offside rear light cluster?...
They’re SJ / Samurai rear lights and don’t feature fog lights
The 2" rear lift springs from JimnyBits turned up this morning, next day delivery... impressive!
And I found a pair of LED fog lights and reverse lights from a previous project (the fastback Jimny) in the garage...
So the fog light is an easy fix, just a bracket here'ish...
And I figured the other one would make a good...
... a good centre hi-level brake light up here at the back of the small winch rope loop, on the back of the halo-hoop..
I decided not to use the reverse lights, as either reverse lights or work lights over the winch area, as I don't plan on greenlaning in the dark...
- Max Headroom
- Banned
- Thank you received: 217
X8GGY wrote: Holy cow, what a load of bull, pull the udder one, I’m sure I’ve herd that before?!
No - seriously - she's looking great - I'm fascinated watching how these projects evolve - wish I had more time not to mention more skills!
New fuel filler and return hoses, old ones were a little too short and very old and floppy
Matching new jubilee clips
Square nuts for the winch mounts... had the right length bolts “in stock” but can I find the original square nuts that came with the winch?!
Is It Sunday Yet? Out to do some more tomorrow
I started early, and hence quietly. by fitting the fuel tank hose(s)... errr, just the return one then? As I'd mis-measured / ordered the filler hose.. so another one is on the way...
I used the 2" offcut though to make an anti-rub end for the cable guide...
And then the missus grabbed me and wanted two blinds trimming to size and hanging, a mirror screwing to the wall, and a hidden-mount shelf putting up... They've been re-decorating the daughters bedrooms, so I couldn't really say No?
So, when I eventually got back to the garage...
I thought I'd have a play with the new
So I bolted down the winch solenoid pack to it's mount, and then tidied all the cables, shortening the positive and negative battery cables, ready to connect to the switch(es)...
Unfortunately, at the front, I've misjudged the size of the standard battery cables, so I've ordered some more crimp connectors hopefully ready for Wednesday... But these are the negative cables, so one to the back winch battery, one to the vehicle's chassis ground, one to the original engine bay wiring (currently bare need a 16mm2 crimp for that) and one over to the engine battery, eventually, when it gets a cradle mount on the passenger side...
And these are the positive cables, so one to the back winch battery (switch), one over to the engine battery, and another two bare 16mm2 original engine bay wires that I also need crimp terminals for..
They'll all connect up in these two connector terminal boxes... soon... I'll paint the bracketry this week before Wednesday, and hopefully the new crimp terminals will also appear in the post on Wednesday...? Get them all bolted in, and hopefully test-fire the engine... it hasn't run for a good while! !
Heat shrink sleeve placed over the cable and then aprrox 12mm of cable sheath removed...
Crimp terminal slipped over the exposed copper cable...
Crimp tool used to make the...
... crimp
and then...
Hot air gun used to heat the heat-shrink sleave...
Et'Voila!
- Thank you received: 1761
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Ordered Sunday when I realised what I was short of... despatched Monday, delivered TUESDAY!
Fitted Wednesday?
I gave the electrical component mountings a first coat of red smoothrite paint...
This afternoon, I had a couple of hours off, so I crimped the connectors on the rear of the battery cables...
Note - I found the solenoid remote control too!
And then, having given the mounts a second coat of paint early in the afternoon, I bolted them in, crimped the rest of the cables and began connecting them up...
Closeup! So the left connector is the negative / earth and has four cables clamped in two pairs either side -
1) The original earth cable in the engine bay
2) An earth to the body
3) The earth cable running to the rear winch battery
4) An earth ready to run across to the engine battery on the passenger side...
And on the right, the right connector also has four cables clamped in two pairs either side -
1) The positive feed to the rear winch battery to charge it (when the switch is ON)
2) A positive ready to run across to the engine battery on the passenger side...
3) Two wires that run into the original main fuse box in the engine bay...
That done, I had a few minutes spare, and started to ponder the excess strap on the spare wheel Y-strap...?
Y-strap with excess strap, scissors (!), blow torch (!!) and wide mole grips?....
No going back now then?!
Heat up the wide mole grips...?
And then clamp them on the end of the cut-off end... and hope for the best?!
Awesome a fused joint on the end to stop it fraying...?!
That;s better!
Cash up the shop, tea and a few beers, write this update... and all ready for another day of tinkering in the garage tomorrow.. Wednesday off
The paint had dried on the switch plates, so I reassembled that and attached some of the cables...
Te switched side of the batteries are connected, but the two going to the actual battery haven't been fitted yet, for a couple of reasons - there's still welding going on on the vehicle, and, I've run out of heat shrink! It's been despatched though, so I can make up the cables one afternoon later in the week...
It being "quite quiet" Wednesday (eldest daughter working in my study above me), I thought I'd change the rear springs (you may remeber the stance of the buggy looked wrong one I pulled it out of the garage for a look the other day),.,
I started with a reference measurement... 7 3/4" to the top of the rear mudguard plate...
Rear spring out - the one on the right is what was fitted, that's a new front spring fitted to the rear to give around 1.5" of lift... the spring on the left is a JimnyBits 2" lift spring - you can see they are the same length, but much meatier on the lift spring...
Bugger! The same amount of lift with the lift spring in?
Ahhh... but on the passenger side Ihave 9" >!
Hmmm...
Lying underneath for a look... notice how tight the coils are compared to...
... the passenger side rear...
Must be the weight of the big winch battery in the offside corner of the rear of the chassis?
Hmmm...
A quick rummage through my old stock, and I found one remaining 15mm spring spacer.. ! And luckily, when I ordered the wrong diameter fuel filler hose, I also therefore ordered the wrong diameter jubilee clips, so they were used to clamp the spring spacer to the top of the offside spring...
That's better! 9" on the offside too... all sorted!
So I then reassembled everything - spring clamps, rear shocks, and then...
I could feel my sugars were dropping a little low, a quick prick test confirmed, so I had a cuppa and a KitKat to bring them back up again...
I then drilled through the X of the "rollcage" brace and the box section top of the little "wadig wall", and added a spacer over the big long bolt...
epeat for the other side, and then (test) bolt the spare wheel strap in place
Yup, happy with that, what's next then...?
LOL Soo, at two o'clock I decided to knock off early, write this, and then head for a shower and take the dogs out for a nice long walk...
So Sunday's a welding and grinding day!
