BigJimnyMeet 2024
Clutch change, How long.
- wanderinstar
- Visitor
12 Dec 2012 16:30 #55396
by wanderinstar
Clutch change, How long. was created by wanderinstar
Has anyone had a garage do a clutch change in an 02 Jimny?
If so how many hours labour did they charge for.
There was a time not so long ago that I would not have dreamed of putting a car into a garage for such a mundane job. But health issues have taken over, sadly.
- reaper
- Visitor
12 Dec 2012 17:20 #55399
by reaper
Replied by reaper on topic Clutch change, How long.
They will probably charge a full day 7-8 hrs ...and they wont be far from the mark mate
- vitara_mad
- Visitor
12 Dec 2012 17:33 #55400
by vitara_mad
Replied by vitara_mad on topic Clutch change, How long.
ive never taken a vehicle to a garage so not sure how many hours they charge for changing a clutch but if they do charge for a full day 7-8 hours they are either not very good at there job or ripping you off a mechanic with a fully equiped garage with lifts should be able to do the job in no more than 3 hours
if you got to take it to a garage you be best taking it to a specialist clutch garage
- Thank you received: 210
12 Dec 2012 17:52 - 12 Dec 2012 18:03 #55402
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Clutch change, How long.
I replaced a gearbox and clutch on my jimny in 5 hours in the pouring rain with the front wheels up on wheel ramps and I've never fitted a gearbox in a jimny before.
Try Mr clutch.www.mrclutch.com/services/clutches
2002 JLX Soft Top
Last edit: 12 Dec 2012 18:03 by dirtydogz.
- Sponnie
- Visitor
12 Dec 2012 18:21 #55403
by Sponnie
Replied by Sponnie on topic Re: Clutch change, How long.
Took me about 5 hours too.
No idea how long a garage would take. To be honest if its an agreed price that your happy with, then it doesnt matter unless ur nuts enough to wait while its done!
Sent from my GT-I9300 using Tapatalk 2
- Smoggy
- Visitor
12 Dec 2012 20:17 - 12 Dec 2012 20:19 #55407
by Smoggy
Replied by Smoggy on topic Clutch change, How long.
I am half way through mine (clutch now removed) and I am very new to the mechanics game and upto about 4hours now. I did follow Martins guide and removed the transfer box, exhaust front pipe, front 2 propshafts and eased back starter the motor (dont know if all that is strictly necessary though )
On a slightly different note I burnt the clutch out offroading and it stunk! Infact I just got it home. The confusing thing is that when I removed it I expected the friction plate to be down to the rivets, but it wasn't
It was very shiny though and had some deep gouges in it. Does this sound right.
Please see pics: any advice appreciated guys.
Last edit: 12 Dec 2012 20:19 by Smoggy.
12 Dec 2012 20:37 #55408
by dirtydogz
2002 JLX Soft Top
I do know if it's a G13BB engine you don't need to remove the transfer box so that save you about 45 mins.
2002 JLX Soft Top
- Smoggy
- Visitor
12 Dec 2012 20:52 #55410
by Smoggy
No its twin cam motor
- vitara_mad
- Visitor
12 Dec 2012 20:59 #55412
by vitara_mad
theres no need to remove transfer box on any jimny to change the clutch ive done g13bb & m13a
im sure we did not remove front prop or exhaust either
- jimnydms
- Visitor
12 Dec 2012 22:22 #55418
by jimnydms
Replied by jimnydms on topic Clutch change, How long.
I have just done clutch on mine 1st jimny clutch I ve done of the floor but have a 4" lift. My clutch was slipping like mad but the plate it's self didn't look that bad as above I expected to see threads and rivets but looked ok.... Havn t drove it yet as only just finished my TG crawler box to go in this weekend so time will tell !
- jimbob
- Visitor
14 Dec 2012 07:19 #55488
by jimbob
Replied by jimbob on topic Clutch change, How long.
Well to tell you all about fitting a clutch in a jimny is like making toast I say this because I fit gearboxes and clutches for a living I can do a jimny clutch box out and back in with in an hour and yes if you took it to a garage they would charge you by the hour or give you a fix price for the job if your paying more than, lets say £350 that's on the high side kk
- 247sniper
- Visitor
15 Dec 2012 11:50 #55565
by 247sniper
Replied by 247sniper on topic Clutch change, How long.
Bloody hell guys, 7-8 hours!
The BOOK time for changing clutch plate,cover and release bearing is only 2.70 hours. even doing the job on axle stands you can get the box out in an hour.
If they charge you any more then 4 hours i would query it or better still when you drop the car off at the garage just highlight the fact that you are aware of the book time only being 2.70 hours.
Steve.
Steve.
Time to create page: 0.113 seconds
