Drill out the bottom stud for rear shocker?
23 Apr 2013 13:03 #69316 by maverick
Hi,
The stud that holds the rear lower shocker has snapped off ...
Does anyone know a good brand of drill bit i can go and buy so I can drill a hole right the way through??
Thanks
Jalapeño, IISY?
23 Apr 2013 13:13 #69317 by mlines
I had to buy a cobalt drill bit as it quickly chewed a standard one.
Sent from my HTC EVO 3D X515m using Tapatalk 2
  • gus2000
23 Apr 2013 16:39 #69323 by gus2000
Replied by gus2000 on topic Drill out the bottom stud for rear shocker?
hi,
if cobalt drill fails, you can try with Titanium Nitride Coated drill
if it fails, you can try with a masonry drill (tungsten carbide) sharpened to steel
Success
Gustavo
  • Dave cc
23 Apr 2013 17:20 #69325 by Dave cc
Replied by Dave cc on topic Drill out the bottom stud for rear shocker?
I drill all sorts of nasty material and use only HSS drill bits you need to keep your speed very slow and apply good heavy pressure with a suitable cutting oil start with a smaller drill bit and work your way up to the size you require.
As any acomplished machinist will tell you its all in the speed and the feeds and wasting money on fancy drills that will either chip or chatter there coating off when you have no rigid set up IMO is a waste of money
  • JerseyJimny
23 Apr 2013 18:47 #69329 by JerseyJimny
Replied by JerseyJimny on topic Re: Drill out the bottom stud for rear shocker?
Dave cc wrote: I drill all sorts of nasty material and use only HSS drill bits you need to keep your speed very slow and apply good heavy pressure with a suitable cutting oil start with a smaller drill bit and work your way up to the size you require.
Amen to that... Not been machining long but you learn that quickly :)
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
23 Apr 2013 21:24 #69344 by maverick
Thanks everyone for, as ever, great advice.
I've had a b1tch of an evening.
First attempt was to get sheared off bolt out using extractor - extractor snapped leaving half of it on :sick:
Subsequent attempt to drill a hole through floundered hopelessly.
In the end we used Mr. A Grinder to cut off the piece of bar (where stud was snapped off) which then allowed to push out snapped-off extractor from other end.
I now need an 11mm drill and get a piece of pipe (similar to angle grinded off) and then a long enough Bolt with a Nylock.
Almost there :)
Jalapeño, IISY?
