Revision as of 20:16, 4 June 2016 by Mlines (talk | contribs)
Front brake pad change
Use the "Print as PDF" tab above to print
Changing the Front Brake pads
Changing the Brake Pads is a simple and quick job within the grasp of most abilities.
So what are the symptoms of worn brake pads:
  • Poor braking
  • Pulling to one side
  • Squealing and judder when braking
  • Assorted screwdrivers
  • Circlip pliers (External)
  • A G-Clamp or piston retraction tool
Removing the Caliper and pads
Jimny Front Caliper
Unbolting the caliper
Open brake caliper
Removing the brake pads
The new pads
Here are the new pads compared with the old, note that ADK84224 are an aftermarket equivalent of the Suzuki part.New pads, are available in the BigJimny Store. The old are worn down to the metal.
OOPS!
The new pads fitted
The new pads then simply push into place held by the spring clips. Place the anti-squeal shims in place, smear a bit of Copper Grease on the rear of the shims to help reduce squeal.
Using a G-Clamp
Now the Piston has to be moved back, I use a G-Clamp and wind the piston back in until it is flush..
All done
Now swing the caliper back into position and bolt up the caliper bolt.
Page last edited on 4/06/2016 by user Mlines
