Support this project: The information and files on this page are free, but they took a lot of work to gather, test and write up. If they have been useful to you, you can say thanks with a donation at buymeacoffee.com/bigjimny.
OBD Project Resources
Links to the main pages, images and files from the Suzuki Jimny JB74 OBD2 diagnostics and RealDash dashboard project, collected in one place.
| Link | Description |
| OBD2 Diagnostics reading project | The main project page: how the data was found, and how to read TPMS, 4WD and ABS/ESP data with an ELM327 or OBDLink adapter in Car Scanner Pro and RealDash. |
| ECU diagnostic CAN addresses | Every module that answers on the JB74's OBD socket, with its request and reply CAN IDs and the data layouts decoded so far. |
| SDL/KWP Diagnostics (Older Gen3) | Diagnostics for older gen3 Jimnys, which use Suzuki SDL (pin 9) and K-Line (pin 7) instead of CAN. |
| 4WD annunciator panel | Brushed aluminium panel and lit and unlit lamp images for 4WD, 4LOW, VSV1, VSV2, VACUUM and NO VACUUM, with set-up steps for RealDash. |
| ABS and ESP panels | ABS and ESP panels with a lamp for each wheel, and an ESP OFF lamp and frame. |
| Bubble level (pitch and roll) | Bubble level faces, indicators and bezel ring for a pitch and roll display. |
| Wheel slip display | Wheel slip display images and inputs. |
