OBD Project Resources
Buy me a coffee
Support this project: The information and files on this page are free, but they took a lot of work to gather, test and write up. If they have been useful to you, you can say thanks with a donation at buymeacoffee.com/bigjimny.
Buy me a coffee
Links to the main pages, images and files from the Suzuki Jimny JB74 OBD2 diagnostics and RealDash dashboard project, collected in one place.
Link Description
OBD2 Diagnostics reading project The main project page: how the data was found, and how to read TPMS, 4WD and ABS/ESP data with an ELM327 or OBDLink adapter in Car Scanner Pro and RealDash.
ECU diagnostic CAN addresses Every module that answers on the JB74's OBD socket, with its request and reply CAN IDs and the data layouts decoded so far.
SDL/KWP Diagnostics (Older Gen3) Diagnostics for older gen3 Jimnys, which use Suzuki SDL (pin 9) and K-Line (pin 7) instead of CAN.
4WD annunciator panel Brushed aluminium panel and lit and unlit lamp images for 4WD, 4LOW, VSV1, VSV2, VACUUM and NO VACUUM, with set-up steps for RealDash.
ABS and ESP panels ABS and ESP panels with a lamp for each wheel, and an ESP OFF lamp and frame.
Bubble level (pitch and roll) Bubble level faces, indicators and bezel ring for a pitch and roll display.
Wheel slip display Wheel slip display images and inputs.
Using the RealDash files
The RealDash description files (.xml) listed above are written for an OBDLink adapter (STN chip), such as the OBDLink MX+, LX or CX. A plain ELM327 does not understand the STN commands they use.
Before loading a description file, clear RealDash's imported inputs. RealDash keeps the inputs from every file it has loaded, and the Jimny files share input names, so a lamp or gauge can stay linked to an old copy that never updates:
  1. Settings → Units & Values → Imported Values: tap and hold the top of the list to select all, then delete.
  2. Select only the new file in the connection settings, then restart RealDash or reconnect.
  3. Re-link any lamp or gauge that used a deleted input, picking it from the fresh list.
More detail is on the project page.
