 - Horizontal play in the front wheel
- With the car jacked up, grip the wheel sides - there will be movement if they are worn.
- Get an assistant to press the brakes while you are shaking the wheel - the movement should disappear.
- It is also common not to experience any play at all and to even pass an MOT with a really bad bearing.
 - This is because the Jimny front wheel bearings have dual inner race and only one race may have failed.
Prerequisites
Required parts
The table
| Wheel bearing  |
1 piece | 43462-84A00 | Various | Suzuki actually uses Koyo "DAC4168W HR4CS23" bearing under the stated OEM P.N. |
| Bearing oil seal  |
1 piece | 09283-54001 | Various | This part is usually available in the aftermarket only in a set together with the bearing. Suzuki originally used the seal with inscriptions "Koyo" and "MHRD 54 69 7.5-9.5SJ" in a Jimny made in 2007.  |
| C-clip | 1 piece | 09381-68001 | Various | This part is usually available in the aftermarket only in a set together with the bearing. |
| Bearing grease  |
A fistful or so  |
? | Various | Sometimes comes together with the bearing (otherwise use a high quality grease which is suitable for the application).  |
| A calendar with pictures of (half)naked women  |
12 pictures / months  |
Probably with portraits of Suzuki's female employees  |
- A complete 3-piece kit (wheel bearing + oil seal + C-clip).
Required tools
 - Assorted screwdrivers
 - Hub nut unlock tool
 - Circlip pliers (External)
 - A ball joint splitter
 - 1" Imperial Socket
You will definitely need the special tool to release the locking hub nut.
Replacement procedure
Removing the Caliper and pads
- First of all secure the car, release the wheel nuts and jack up the car and remove the road wheel.
 - This then reveals the brake caliper, this is the passenger side (nearside) caliper (UK)
 - If the pads resist, gently prise out the pads with a small screwdriver - do not remove the spring clips.
Removing the Brake Disc
- The caliper is held on with two bolts at the rear.
 - If you are lucky it will simply pull off but if you have problems then there are two M8 holes in the disk hub.
Dismantling the Hub
- With the hub removed the driveshaft is exposed.
 - The driveshaft is retained with a circlip so use a pair of circlip pliers to remove it.
- Now for the special tool.
 - The hub is held on by a special round nut that requires a special tool to release it.
 - The outside of the nut is a smooth polished ring which is part of the vacuum seal so it must not be damaged.
 - Otherwise you will need a new nut (which is exceedingly expensive!).
 - In the centre of the nut, the edge is bent over into a slot to help secure it.
 - The slot can be seen in the photo in the “2 o’clock” position.
 - Use a blade to bend the edge back into line.
 - It is essential that this is completely free, otherwise it is impossible to undo the nut and you will break the tool.
- This is the tool.
 - It is available from the BigJimny Store.
 - Make sure that the tool and the nut are completely clean as the tool will not fit.
 - Make sure the tool is inserted into the nut correctly with the pins all in the holes in the nut.
 - You are really going to have to swing on the nut to release it.
 - I had to use a long breaker bar AND a piece of scaffold tube.
 - With the nut removed the hub should be removeable, it might need a pull with a slide hammer, mine just pulled off by hand.
- With the hub face down on a surface you can now remove the bearing seal from the rear of the hub.
 - I prised mine out with a screwdriver.
- Then you can use a pair of long nose pliers to remove the C-Clips that retain the bearing.
 - Note that these may be corroded in and difficult to even see at first.
- Now comes the first bit that is supposed to be difficult.
 - Suzuki say that the bearing needs to be removed using a press.
 - I decided to have a go myself - using an old piece of bearing and a steel pin I hammered out the bearing and it only took two or three swift blows.
 - The picture shows the steel pin resting on the bearing before being hit.
 - Note the use of the brake disk to provide a holder for the hub allowing the bearing to be driven out of the bottom.
- The bearings are Koyo brand as standard.
 - The BigJimny store has a kit available which includes the seal and the c-clips (not all kits contain the c-clips), the Wheel Bearing Kit is here.
The rebuild
- Suzuki says the new bearing needs to be pressed into place.
 - I decided to try a bit of school boy physics.
 - I coated the bearing in Copper Grease and then put it in the deep freeze overnight.
 - The hub was placed in the oven at 180 degrees for 30 minutes.
 - So with an ice cold bearing and a very hot hub I put the bearing in the hub, placed the old bearing ring and the steel pin on top and tapped the bearing straight into place.
 - It took two gentle hits!
 - Again note the use of the brake disk to hold the hub.
- Once it is cooled put grease into the ends of the bearing.
 - Then insert the new circlip and the oil seal.
 - I found that the oil seal pressed in ok by hand once coated in Copper Grease.
 - The oil seal has a protruding lip, this must be to the outside of the joint.
 - Grease the inside of the bearing and slide the hub back onto the driveshaft.
- Grease the hub nut and tighten the nut using the special tool
 - Torque it to 220NM or 160ft lbs – ie. really tight!.
 - Use a punch to bend the inner lip of the nut to lock it in place.
 - Refit the hub thrust washer and circlip to the driveshaft.
- Fit the disk and fit the caliper (Caliper bolts 61ft/lbs), brake pads and bolt the caliper down in position (Caliper pin bolt 16/ft/lbs)
Full details of the torque settings can be found in the  reference data
Page last edited on 15/01/2019 by user Bosanek
