If you off-road a Jimny (or any of the Suzuki classic 4wd vehicles) then this is a job you will become familiar with.
It is also one of the worst in my opinion, not because it is difficult, but because of the smell, you will find out what I mean later.
It is also closely tied in with changing/working on the wheel bearings so some of the steps are duplicated.
The symptoms of worn KingPin bearings:
- Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement if they are worn, get an assistant to press the brakes, if it still wobbles then it is the Kingpin bearings.)
It is also common not to experience any play at all and to even pass an MOT with a really bad bearing.
This is because the bottom bearing in particular can rust solid so no play is detectable.
The worst Jimnys for this are often the "one careful lady owner" ones that have sat for long periods on the driveway with the bottom bearing rusting away.
Changing the bearings
- Assorted screwdrivers
- Circlip pliers (External)
- A ball joint splitter
- 1" Imperial Socket
The Video
Before you read the guide below, you may wish to view the video.
This shows the changing of the Kingpin Bearings on a Jimny fitted with ABS so you will see me remove the sensor etc.
The rest of the guide below shows the same task in a series of steps for clarity.
Removing the Caliper and pads
- If the pads resist, gently prise out the pads with a small screwdriver - do not remove the spring clips.
Removing the Brake Disc
- The picture below shows a bolt being used to push the disk off the hub.
Dismantling the Hub
- It is essential that you get this correct, else the hub will not work again.
- Ff the joint rotates, then put a jack under the joint and lift the car slightly to lock the joint.
- There are two sets, top and bottom and they must not be mixed up.
- If you are doing both sides at once then do not mix them across either!
- The hub will now pull off.
- Beware, if they are badly worn the hub will be full of stinking grease, oil and water so make sure you can capture the mess in something.
- This is the bit I hate because of the smell!
- That’s water pouring out of the axle! Also shown is a worn out bearing.
- The bearings are Koyo brand as standard.
- The BigJimny store has two kits available, the basic kit has the two bearings and the small oil seal required to do one side.
- The full kit also included the large external seal although some people choose not to change this.
- The thing to remember is that it is not a Landrover which has oil filled swivels.
- The joints on Jimnys should be "dry" apart from some lubricating grease.
- Clean the swivels inside and out, clean the knuckles and pull out the drive shaft and clean that as well.
The rebuild
- Once clean you can start the rebuild process.
- The KingPin bearings come in two parts, the race and an outer ring.
- This ring is still in the swivel and needs driving out.
- A simple way to drive them out is to use a 1" Imperial socket.
- Using an extension bar fed through the swivel, place the 1" Socket behind the ring and drive it out by hitting it.
- Picture from Dave at Bits4Vits
- The new rings can then be driven into place with a piece of wood to protect them from the hammer.
- Again, this is seen in the video (picture needed here).
- I also hooked out the small axle shaft oil seal and put a new one in from the BigJimny kit. (picture needed here).
- Here is the completed swivel with new rings and oil seal (and plenty of copper grease to help them all into place.
- The confusing part is the order of the seals and rings on the swivel.
- The pictures below show the correct orientation.
- Note also that the slits in the retainers go to the top.
- I find the easiest way to grease the bearings is to put them in a polythene bag with some grease.
- Then use the bag to squeeze the grease into the bearing, this can be seen in the video. (picture needed here).
- Again, the BigJimny shop sells suitable sealant.
- Make sure that you have put the correct Kingpin in place, remember you should have marked them when you dismantled it!
Page last edited on 24/01/2017 by user Bosanek
