Changing the Kingpin Bearings
- Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Changing the bearings
- Assorted screwdrivers
- Circlip pliers (External)
- A ball joint splitter
- 1" Imperial Socket
The Video
Removing the Caliper and pads
Removing the Brake Disc
Dismantling the Hub
The KingPins are also held in with sticky sealant so you will need to prise them out. The hub will now pull off. Beware, if they are badly worn the hub will be full of stinking grease, oil and water so make sure you can capture the mess in something. This is the bit I hate because of the smell!.
That’s water pouring out of the axle! Also shown is a worn out bearing.
The rebuild
Once clean you can start the rebuild process. The KingPin bearings come in two parts, the race and an outer ring. This ring is still in the swivel and needs driving out. A simple way to drive them out is to use a 1" Imperial socket. I do not have a picture of this process but it is shown in the video. Use the 1" Socket behind the ring and drive it out by hitting it. (picture needed here)
I also hooked out the small axle shaft oil seal and put a new one in from the BigJimny kit. (picture needed here)
