Which Oxygen/Lambda sensor?
  • markspend01
20 Jul 2013 09:39 #77624 by markspend01
Replied by markspend01 on topic Which Oxygen/Lambda sensor?
markyp2000 wrote: How many sensors do you have on your car
Hey Guy well i think its depend on the car. A common ABS is consisting of a main digital management device four wheel speed sensors,one for each rim and two or more gas valves within the braking mechanism hydraulics.
  • markyp2000
20 Jul 2013 09:48 #77625 by markyp2000
Replied by markyp2000 on topic Which Oxygen/Lambda sensor?
How have you got from an exhaust lanbda sensor to the abs system?
Have i missed somthing along the way
The 17 years iv been working on cars iv never changed a brake abs sensor cos the engine ecu said it was a EXHAUST LAMBDA SENSOR
20 Jul 2013 22:42 #77717 by Rhinoman
markyp2000 wrote: Have i missed somthing along the way
Spam bot - check out the posters other posts too, a valiant attempt but ultimately utter drivel.
  • helijohn
21 Jul 2013 08:31 #77725 by helijohn
Replied by helijohn on topic Which Oxygen/Lambda sensor?
What are the symptoms of a failing/failed sensor please.
21 Jul 2013 17:34 #77760 by Rhinoman
It'll usually start to run a little rich, if you were to examine the waveform you'd see that it switches much slower than a new sensor.
The following user(s) said Thank You: helijohn
  • Osborne
03 Aug 2013 07:11 #78832 by Osborne
Replied by Osborne on topic Which Oxygen/Lambda sensor?
Aaaaargh!,,
Well, back again!! Sensors replaced & ecu reset.....same problem! I'm guessing now that there's a broken wire somewhere, any one else had this problem or know of an obvious place to start looking?
Thanks in advance guys
Time to create page: 0.199 seconds
