double din radio trim for later Jimnys??
  • Zee Zee Top
19 Oct 2013 14:18 #87027 by Zee Zee Top
Replied by Zee Zee Top on topic double din radio trim for later Jimnys??
once more
  • gilburton
19 Oct 2013 14:36 #87031 by gilburton
Replied by gilburton on topic double din radio trim for later Jimnys??
Didn't know that but it's now discontinued.
Only snag with the package was the price at over £400 or £475 fitted but the panel might have been a good option.
  • Zee Zee Top
19 Oct 2013 15:14 #87035 by Zee Zee Top
gilburton wrote: Didn't know that but it's now discontinued.
Some dealers must still have the bits. looks like a ring around job.
22 Oct 2013 12:58 - 22 Oct 2013 16:59 #87485 by Halford
Ok I've given this all thought as was looking to fit a single DIN CD/Radio with a single DIN tray (eventually to replaced with a CB), and have discussed the options below as it may be of use to someone else
1.) the original fascia on a 2005+ double DIN (like mine) has a curved corner hole as below measuring 188mm wide x 103mm deep
2.) the 11-357 Radio Facia for SUZUKI Jimny Fascia Dash Kit Panel Plate Surround Fitting from Hong Kong for £13 simply fits into the original curved fascia (note the curved edges) to create a recess measuring 173mm x 98mm which is the size for 99% of Double DIN car audio head units (such as Pioneer, Alpine, Sony, JVC, Kenwood, Panasonic etc)
3.) Suzuki supply a replacement fascia (73821-76J10-5PK) £40 ish which features a square edged recess that measures 188mm wide x 111mm deep, and when the Pioneer double DIN head unit was available, they supplied a trim panel that took it down to 173 x 98mm.
now I've just measured my single DIN CD/radio at 182mm x 53mm, so it should fit my existing curved edge fascia which is 188mm wide leaving slight gaps at either side but hopefully not leaving a top gap, however that only leaves 103mm - 53mm = 50mm depth to fit a tray (eventually a CB) and typical trays "fronts" measure 188mm by 56mm :ohmy:
but what the hell, I'm going to order one and see what I can do with dremmel :pinch:
will post an update when done :S
Last edit: 22 Oct 2013 16:59 by Halford.
  • Jutwit
16 Feb 2014 23:38 #104807 by Jutwit
Replied by Jutwit on topic double din radio trim for later Jimnys??
Halford wrote: Ok I've given this all thought as was looking to fit a single DIN CD/Radio with a single DIN tray (eventually to replaced with a CB), and have discussed the options below as it may be of use to someone else
Any progress on this?
  • gilburton
21 Feb 2015 08:44 - 21 Feb 2015 08:53 #138665 by gilburton
I know this is an old post but did you ever get this sorted Halford??
Is there a cheaper way to get a modern double din unit in the later Jimny without paying £108 for a new fascia??
Does anyone know if the VW trim panel is anywhere near the Jimny size as it looks very similar with round corners ??
I notice on the new brochure for the latest Jimny the pioneer unit and facia trim(same part number) appears to be available again.
Last edit: 21 Feb 2015 08:53 by gilburton.
Time to create page: 0.199 seconds
