Installing air filter service indicator
  • gus2000
23 Apr 2013 00:30 #69297 by gus2000
When using the off-road vehicle, the periods of air filter replacement are dependent dust sucked. Not the distance traveled or time of use.
When did replace the air filter?
When depression after the filter reaches values above 50 mbar
How we measure this?
The yellow piston indicates the depression after the filter
Here indicating 65% % depression after the filter (full scale 50 mbar)
Installing in the air filter case.
when replacing air filter release the yellow piston indicator to press the yellow button
In five minuts
No more clogged filters
No more new filters thrown in the trash
Cheers
Gustavo
  • VAXXi
23 Apr 2013 07:03 - 23 Apr 2013 07:05 #69303 by VAXXi
Replied by VAXXi on topic Installing air filter service indicator
What will they think up next :dry: nice trick though !
Last edit: 23 Apr 2013 07:05 by VAXXi.
  • Laminak
23 Apr 2013 07:57 #69304 by Laminak
Replied by Laminak on topic Installing air filter service indicator
It's a good idea to install this indicator :-)
  • adamatdraycott
23 Apr 2013 08:41 #69306 by adamatdraycott
Replied by adamatdraycott on topic Installing air filter service indicator
For the sake of £10 for a genuine one on ebay... i just stick a new one in every 12months... can't be bothered to fire the compressor up
26 Apr 2013 19:42 #69536 by Rhinoman
If you have a diagnostic interface then you can log manifold pressure and barometric pressure at WOT through peak torque (around 3500rpm). Check it with a new filter so you know what it should be and then you can check it at regular intervals. I would expect a 50mBar difference stationary to be a big difference at WOT as there will be a lot more air trying to get through or is it on some sort of ratchet?
