Trailmaster 50mm (2") Lift Kit - 2019
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
Product Information
Specification
SALES TEMPORARILY SUSPENDED DUE TO PROBLEMS WITH GERMAN COURIERS
This is the lift kit for the Generation 4 Jimny. Many people have reported over the years on how good the other kits in the Trailmaster range are for road manners. Many Jimnys have to spend a good part of their life on the road going shopping, to school or work. Extreme lifts give the already less than ideal road handling of a Jimny a real turn for the worse. However this kit, through its use of quality products and good design, retains the Jimnys road handling and, on our Jimmy, positively improved the normally "crash/bang" ride over the bumps.
Two versions are available, please select the required option.
1. With castor correction bushes that the manufacturer recommends when fitting large tyres to the Gen4 Jimny using this kit.
2. Without castor correction, the manufacturer recommends this for standard tyres only.
NOTE: THE PICTURE IS NOT NECESSARILY REPRESENTATIVE OF THE KIT - I AM AWAITING ACTUAL PICTURES
Delivered direct to you from the manufacturer (takes about 5 -7 working days).
Postage to UK is included in the price.
See www.bigjimny.com/index.php/entry/793-littlejimny-grows-up for my own build.
This kit raises your vehicle 50mm, this is not a vast lift but a lovely "just right" height before you get into major modification issues.
The kit contains:
  • +50mm Front and Rear spring sets
  • +50mm Front and Rear shock sets
  • Correction bushes (as an option)
  • LED Headlamp adjuster bracket (e.g.for UK SZ5 models)
  • Extended rear brake hose
  • Extended bump stops.
  • Fitting instructions and TUV certification
Here are some related videos, including the installation:
BREXIT
I import the Trailmaster Kits from the EU into the UK and therefore costs are subject to the EURO/£ exchange rate. I try to keep the cost of the kits competitive which means only a small margin for me. Because of the small margin I am exposed to any significant swings in exchange rates.
I will try and maintain the pricing but should the £ to Euro rate move significantly. I may have to re-quote people after they have submitted an order in order to protect me. In the event that the revised price is not acceptable to the purchaser a full and immediate refund will be given.
Product CodeGen4 Trailmaster
ManufacturerTrailmaster
ConditionNew
Weight111.111Kg
Customer Reviews
Write a review
Write Review
Top
eCommerce by CubeCart
