The purpose of this page is to simply list the factory specified tightening torques for various fasteners in the vehicle.
Axle
| Fastener | Jimny 3 | Jimny 4 | ||
| [Nm] | [lb-ft] | [Nm] | [lb-ft] | |
| Radius Arm bolts (Axle) | 90 | 65 | ? | ? |
| Radius Arm bolts (Chassis) | 90 | 65 | ? | ? |
Differential, front and rear
| Differential Drain Plug | 27 | 19.5 | 55 | 40.5 |
| Differential Filler Plug | 50 | 36.5 | 50 | 36.2 |
| Prop Shaft Flange Bolts | 50 | 36.5 | ? | ? |
| Bevel Gear Bolts | 85 | 61.5 | ? | ? |
| Bearing Cap Bolts (front) | 50 | 36.5 | ? | ? |
| Bearing Cap Bolts (rear) | 85 | 61.5 | ? | ? |
| Lock Plate Bolts | 11.5 | 8.5 | ? | ? |
| Front and Rear carrier bolts | 23 | 17 | ? | ? |
| Gear Thrust Bolt (front) | 1.5 | 0.1 | ? | ? |
| Gear Thrust Bolt (rear) | 85 | 61.5 | ? | ? |
Front Wheel Hub
| Wheel Nuts | 95 | 69 | 100 | 72.3 |
| Tie-Rod End Nut | 43 | 31.5 | ? | ? |
| Kingpin Bolt | 25 | 18.0 | ? | ? |
| Locking Hub Bolts | 48 | 35 | ? | ? |
| Swivel Seal Bolts | 10 | 7.5 | ? | ? |
| Brake Carrier Bolts | 85 | 61.5 | ? | ? |
| Wheel Bearing Lock Nut | 220 | 160 | ? | ? |
| Drop-Link/Stabilizer Link ball nut | 50 | 36.5 | ? | ? |
| Brake Caliper Slider Bolt | 22 | 16 | ? | ? |
| Front Brake Flexi Hose bolt | 23 | 17 | ? | ? |
| Wheel Spindle Bolt | 50 | 36.5 | ? | ? |
Engine
| Fastener | Jimny 3 | Jimny 4 | ||||||
| Engine G13B | Engine M13A (VVT) | Engine K9K | Engine K15B | |||||
| [Nm] | [lb-ft] | [Nm] | [lb-ft] | [Nm] | [lb-ft] | [Nm] | [lb-ft] | |
| Oil drain plug | ? | ? | ? | ? | ? | ? | 35 | 25.8 |
| Oil filter (3/4 turn) | ? | ? | ? | ? | ? | ? | 14 | 10.3 |
Gear box
| Fastener | Jimny 3 | Jimny 4 | ||||||||||||||
| Petrol | Diesel | Petrol | ||||||||||||||
| Automatic | Manual | Automatic | Manual | |||||||||||||
| Code ?? 1998-2005 |
Code ?? 2005+ |
Code R7ME 1998-2005 |
Code R72 2005+ |
Code YR7D 2003-2005 |
Code ?? 2005-2011 |
Code ?? 2018+ |
Code ?? 2018+ | |||||||||
| [Nm] | [lb-ft] | [Nm] | [lb-ft] | [Nm] | [lb-ft] | [Nm] | [lb-ft] | [Nm] | [lb-ft] | [Nm] | [lb-ft] | [Nm] | [lb-ft] | [Nm] | [lb-ft] | |
| Fill and drain plugs | ? | ? | ? | ? | ? | ? | 23 | 17 | ? | ? | ? | ? | ? | ? | 23 | 16.6 |
| Reverse Switch | ? | ? | ? | ? | ? | ? | 23 | 17 | ? | ? | ? | ? | ? | ? | ? | ? |
| 5th gear shift inverse lever bolt | ? | ? | ? | ? | ? | ? | 23 | 17 | ? | ? | ? | ? | ? | ? | ? | ? |
| Transmission case bolt | ? | ? | ? | ? | ? | ? | 23 | 17 | ? | ? | ? | ? | ? | ? | ? | ? |
| Gear shift rod spring / ball bearing bolts | ? | ? | ? | ? | ? | ? | 13 | 9 | ? | ? | ? | ? | ? | ? | ? | ? |
| Gear box case to engine nuts and bolts | ? | ? | ? | ? | ? | ? | 90 | 65 | ? | ? | ? | ? | ? | ? | ? | ? |
Transfer box
| With mechanical lever |
Without mechanical lever |
With mechanical lever | ||||
| Fill and drain plugs | ? | ? | ? | ? | 23 | 16.6 |
Other
| Chassis to body mount bolts | 60 | 44 | ? | ? |
| All bolts which fasten any of the seat belts to the vehicle | 35 | 26 | ? | ? |
Page last edited on 11/08/2020 by user Bosanek
