Revision as of 09:32, 24 February 2019 by Bosanek (talk | contribs) (Minor phrase correction)
Drive belts
  • This article deals with the engine drive belts and associated tensioners, their configurations and adjustment.
  • Petrol Jimnys have an auxiliary belt (fan belt) and a power steering belt.
    • There are a number of combinations and it is essential you get the correct belt.
  • Diesel Jimnys have one auxiliary belt which drives all auxiliary engine devices.
You should not purchase based on guidance below - you should identify the correct belt for your vehicle elsewhere.
Nomenclature
For shorter naming, these abbreviations and designations will be used in this article:
  • P.S. - Power Steering
  • A.C. - Air Conditioning
  • G13BB - petrol engine, used in very early petrol Jimnys gen3 and many cabrio / open top petrol Jimnys gen3;
  • M13A / M13AA / M13A VVT - family of petrol engines, used in most petrol Jimnys gen3 from 2001 to 2018;
    • All variants of this engine are effectively the same from the "drive belt choice" perspective;
  • K9K - Renault's diesel engine, used in all diesel Jimnys gen3;
    • This engine exists in two variants, but both are effectively the same from the "drive belt choice" perspective;
  • K15B - petrol engine, used in Jimnys gen4;
G13BB with P.S. but without A.C.
G13BB with PAS
  • PAS: Adjust mid point of belt between Pump and Crank (lower belt section) to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
  • Shop for V-Belts in BigJimny Shop
G13BB with P.S. and with A.C.
G13BB with PAS and Aircon
M13AA with P.S. but without A.C.
M13AA with PAS
  • Auxillary Belt - known part number for some models 95141-50F01
  • PAS:Adjust mid point of belt between Pump and Crank (lower belt section) to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
M13AA with P.S. and with A.C.
M13AA with PAS and Aircon
  • PAS+Aircon Belt - known part number for some models 17521-52E00
  • PAS: Adjust horizontal (bottom) of belt to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
M13AA without P.S. but with A.C.
M13AA with PAS
  • Aircon: Adjust horizontal (bottom) of belt to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
K9K
  • Info needed ...
K15B
  • Info needed ...
Tensioners for Jimnys gen3
There basically two types of tensioners for petrol Jimnys gen3:
  • One with a small center;
    • These are more common on the G13B engines;
  • One with a large center;
    • There are more common on the M13A family of engines;
You should not purchase based on guidance below - you should identify the correct tensioner for your vehicle.
Small hole tensioner
  • This is Suzuki part number 49160-82A00.
  • If the bearing has worn, then it can be replaced by pressing the old bearing out.
  • A suitable bearing is available in the BigJimny Shop HERE
Large hole tensioner
  • This is Suzuki part number 49160-81A00.
  • This tensioner is commonly called a "smilely tensioner" because of the appearance.
  • If the bearing has worn then it can be replaced by pressing the old bearing out of the outer rim and pressing the smilely centre out.
Replacements
  • First of all, the BigJimny shop has a high quality replacement bearing for sale (read above).
  • However, if you for some reason want to replace the entire tensioner assembly (generally a lot more expensive), you can either buy the original Suzuki P.N. 49160-81A00, or one of the aftermarket tensioners.
  • By the way, the bearing which Suzuki originally installs in this tensioner is NSK 6010DU2 (that's at least the case in M13A engined Jimnys made in 2013).
    • That bearing has rubber seals on both sides.
    • Specifications are: single-row, ball bearings, deep groove, 50 x 80 x 16 mm
  • NSK has allegedly superseded it with the bearing model 6010DDU.
    • However, since the specifications of those two bearings appear to be the same, it could very well be the same bearing, but just a changed naming nomenclature.
  • There is also a "premium" edition of this bearing.
  • The "VV" suffix means that is has special "contactless" double sided rubber seals (and made of some super tech rubber), which effectively allow far higher bearing RPMs and operating temperatures.
    • However, this premium bearing is about 3x more expensive than the "ordinary" one.
  • This premium bearing may be an "overkill" for this application (in other words, the standard bearing may be sufficient), but an expert should give an opinion.
    • However, if someone wants to indulge themselves with this premium bearing edition (instead of using chocolate or sex dolls for a change), then buy NSK 6010VV.
Tensioners for Jimnys gen4
Info needed ...
Page last edited on 24/02/2019 by user Bosanek
