Yet another source of poor steering on a Jimny is a worn tie rod / track rod end.
These are a simple job to change, although you should then get the alignment checked/set afterwards.
Diagnostics
- First, find out which one is worn.
- Jack up the vehicle on the side you want to check and make sure the vehicle is secured.
- Place your hand carefully and lightly over the joint and with a firm grip on the steering rod.
- Try and shake the steering rod around in all directions.
- If you can feel a shift or mechanical click/movement in the joint, then it is worn.
Removal
Step 1
- Once you have confirmed that there is a problem, the task of stripping is actually quite easy.
- First remove the wheel, it gives you more room.
- Now use a splitter to break the joint open.
- Here I am using a puller.
- I have undone the tie rod end nut but NOT removed it fully.
- I have put the end of the puller inside the “dish” created by the loose nut on the end of the joint.
- I then put the puller feet into the gap between the rubber and the control arm that the joint attaches to.
Step 2
- The joint should then split with a bang.
- Now you have to remove the joint.
- The trick here is to unscrew the joint without disturbing the locking nut position.
- The locking nut position is what sets the alignment of the steering.
- It is best to try and not disturb it too much so that the alignment is not too far out.
- The joints can rust in and can be very difficult to undo.
- However, I was lucky and it was possible to wind the joint off the rod without touching the locking nut.
- Note that in the picture the locking nut appears to be part of the tracking rod itself as it is corroded on.
- The nut is in fact separate and may need undoing half a turn to allow the joint to be unwound.
Step 3
- With the tie rod removed, put a mark on the locking nut and then remove the nut, counting the whole turns it takes to come off.
Installation
Step 1
- Now count the same number of turns as you wind the nut onto the new joint.
Step 2
- Wind the whole joint onto the rod and re-assemble.
- You will probably find that when tightening the top nut on the joint, the whole assembly simply turns.
- You need to put some pressure on the joint to stop it rotating whilst you are tightening it.
- Here I have placed a jack underneath the joint and jacked up the joint slightly.
Step 3
Now tighten up the locking nut, replace the wheel and you are finished.
Aftermath
You should get the alignment checked and adjusted in a professional work station as soon as you can.
