- 1 A guide to changing the clutch.
- 1.1 Introduction
- 1.2 Changing the Clutch
- 1.3 Removing Interior Items
- 1.4 Draining the Oil
- 1.5 Removing Front Exhaust Section
- 1.6 Removing the Prop shafts, Transfer Box & Gearbox Remote Mechanism
- 1.7 Removing the Engine Mounting Bolts, Starter Motor and Clutch Cable
- 1.8 Seperating Gearbox away From Engine
- 1.9 Replacing the Clutch
- 1.10 Refitting the Gearbox
Changing the Clutch
- Assorted screwdrivers
- Breaker bar
- Clutch alignment tool
Centre Console
To remove the gearbox lever you have to remove the centre console. This is held on by four screws on the side at the front and back. The console then lifts out.
Mine was more of a problem as I have a switch panel fitted so I then needed to remove the gearlever before the console would come completely away, but this has to be done at some point anyway.
Gear levers
Lower Gaiter
Transfer Lever
Draining the Oil
On my Jimny the drain plugs are square and therefore a SQUARE 10MM drain plug socket should be used, however the square end of a 3/8 socket driver fits if you are pushed. Always undo the filler plug first because if the filler is stuck you do not want to drain the oil and not be able to fill it again. The gearbox filler is hidden up the side of the gearbox and lack of space is a problem
Exhaust
Lambda Sensor
Prop shafts
Transfer Box
Engine Mounting
Reversing Switch
Starter Motor
Clutch Cable
Page last edited on 8/06/2016 by user Mlines
