Revision as of 19:46, 4 June 2016 by Mlines (talk | contribs)
Drive belts
Print this page as a PDF
Drive Belts
This section covers the engine drive belts, their configurations and adjustment. The Jimny has an Auxillary Belt (Fan Belt) and a Power Steering Belt.
Do not purchase based on guidance below - you must identify the correct belt for your vehicle
G13BB with Power Steering
G13BB with PAS
  • PAS: Adjust mid point of belt between Pump and Crank (lower belt section) to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
G13BB with Power Steering and Aircon
G13BB with PAS and Aircon
  • PAS: Adjust horizontal (TOP) of belt to 3 – 4 mm (0.12 – 0.16 in.) of flex by adjusting tensioner
M13AA with Power Steering
M13AA with PAS
  • Auxillary Belt - known part number for some models 95141-50F01 (4PK835)
  • PS Belt - known part numbers for some models 17521-84H00 (4PK950) (2007 VVT) or 17521-52E00 (4PK850) (2005 VVT)
  • PAS:Adjust mid point of belt between Pump and Crank (lower belt section) to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
M13AA with Power Steering and Aircon
M13AA with PAS and Aircon
  • PAS: Adjust horizontal (bottom) of belt to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
M13AA with Aircon
M13AA with PAS
  • Aircon: Adjust horizontal (bottom) of belt to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
Page last edited on 4/06/2016 by user Mlines
