Jump to navigation
Jump to search
Changing the Kingpin Bearings
- Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Changing the bearings
Removing the Caliper and pads
Removing the Brake Disc
Now the front brake disc can be removed. If you are lucky it will simply pull off but if you have problems then there are two M8 holes in the disk hub. Simply run two bolts into these holes and the disk will push off the hub. The picture below shows a bolt being used to push the disk off the hub. |
