Suzuki Jimny JB74 (2018+) - Reading TPMS data over the diagnostic CAN link
Support this project: The information on this page is free, but it took a lot of work to gather, test and write up. If it has been useful to you, you can say thanks with a donation at buymeacoffee.com/bigjimny.
Overview
Purpose-built diagnostic tools (Autel, Launch and similar) already support Suzuki comprehensively. There is also a trend towards replacing the factory head unit with an Android media unit that can run apps to read and display information from the car's electronics. These units are not Suzuki-specific, so this project aims to learn how to read vehicle data (starting with the factory TPMS) and show it on the head unit.
Equipment
| Role | Item |
| Head unit | XTRONS PX90 |
| OBD-II Bluetooth dongle 1 | Generic ELM-based (Chinese) |
| OBD-II Bluetooth dongle 2 | Veepeak OBDCheck BLE+ (BLE only; works on a Lenovo tablet, will not connect to the head unit) |
| CAN bus monitor (Windows) | PCAN-View (PEAK-System) |
| Diagnostic tool 1 | Launch X431 CRP919 |
| Diagnostic tool 2 | SZ Viewer app |
| Apps tried | Torque Pro (fails past the first line; tested on a Lenovo tablet), Car Scanner Pro (works), RealDash (TPMS values seen in its debug view; gauges in progress) |
| Head-unit Bluetooth | xTRONS IP90 - Classic Bluetooth only, no BLE support |
Method
- The diagnostic tools (Launch X431, SZ Viewer) have comprehensive Suzuki support, so they are used to generate the CAN bus requests.
- PCAN-View is connected to the OBD socket to capture the requests and the module's replies, which are then decoded by hand.
- The decoded requests are recreated in the head-unit apps so the head unit can ask the car for the same data directly.
Status: work in progress. Based on one RHD UK-market 2021 Jimny with factory TPMS, owner-made PCAN-View captures (including a full Launch scan, an instrument cluster test and SZ Viewer TPMS captures checked against its screen) and the Suzuki parts catalogue. TPMS readings work in Car Scanner Pro; RealDash works in its debug view with gauges in progress. Items marked unconfirmed are not yet verified.
- The TPMS control module answers an ordinary diagnostic request on the OBD socket. It does not broadcast tyre data.
- Request ID 0x798, reply ID 0x7A8 (11-bit CAN, 500 kbit/s, ISO-TP framing) returns the TPMS data, including four sensor IDs and pressure readings. The module's identification reply (37160-61M0) matches the Model No. (P61M0) on the TPMS controller label. Whether the central gateway forwards or remaps the request is unconfirmed.
- Service 0x21 (read data by local identifier), identifier 0x00, returns 102 bytes containing the module supply voltage and all four sensor records.
- Each sensor record gives the wheel position (byte +4), air temperature (byte +5: °C = raw − 50) and pressure (byte +6: bar = raw x 0.01372).
- The OBD socket is fed by a central gateway, so only diagnostic traffic is visible on it.
- Working: Car Scanner Pro, and RealDash (values seen in its debug view). Not working: Torque Pro.
- All the module addresses, and the full byte-by-byte decode of the TPMS data block, are kept on ECU diagnostic CAN addresses.
DLC (OBD socket) wiring
Suzuki numbers the DLC terminals differently from SAE J1962. For all five wired terminals, Suzuki terminal n matches standard pin 17 - n.
| Suzuki terminal | Standard pin | Function | Wire / source |
| 1 | 16 | Battery +12 V | GRY, fuse No.49 "DOME2" (10 A) |
| 12 | 5 | Signal ground | BLK |
| 13 | 4 | Chassis ground | BLK |
| 11 | 6 | CAN-H (from standard assignment) | BLU, gateway pin 8 |
| 3 | 14 | CAN-L (from standard assignment) | WHT, gateway pin 7 |
Use pins 6 and 14 for a CAN adapter.
Cross-check with other reports
A BigJimny forum thread ("JB74 OBD2 connection", December 2020) describes a 2020 JB74 whose OBD plug had pins 4, 5, 6, 14, 15 and 16 wired, with pin 7 (K-line) not wired. The poster, quoting an older Suzuki pinout, lists pin 6 as a blue wire (CAN-H) and pin 14 as a white wire (CAN-L). This matches the table above: a blue CAN wire on pin 6 and a white one on pin 14.
- The CAN-H/CAN-L assignment in that thread comes from a pinout reference that the poster says predates the JB74, so it is a report, not a measurement.
- Standard pin 7 (K-line) has no wire in the table above, and the forum report also found it unwired. K-line is therefore unlikely to be available on the JB74 socket.
- On the forum poster's car, pin 15 was also wired; the table above has no wire for it. This may be a market or model-year difference.
Network layout
The DLC is not on the vehicle bus directly. The central gateway control module joins the vehicle CAN bus (its pins 20 and 21, RED/WHT) and provides a separate CAN pair to the DLC (its pins 8 and 7, BLU/WHT).
Modules on the vehicle bus: ECM, 4WD control module, TCM (A/T models), BCM, ESP control module, headlight auto levelling module (if equipped), dual sensor brake support control module (if equipped), P/S control module, steering angle sensor, TPMS control module / receiver (if equipped), combination meter, SDM, combination switch.
Gateway power: fuse No.60 "IG1 SIG" (10 A) and fuse No.52 "CONT" (5 A). Treat the ignition as needing to be on.
Observation: two captures from the DLC contained only IDs 0x798 and 0x7A8 (plus two error frames). No broadcast traffic from other modules was seen, so passive listening on the DLC will not show TPMS data.
Diagnostic requests seen
| Request | Reply | Meaning |
3E |
7E |
Tester present |
1A 8A |
5A 8A + ASCII 37120-78R0* |
ECU identification |
1A 8E |
5A 8E + ASCII 37160-61M0 |
ECU identification: matches the "Model No. P61M0" printed on the TPMS controller label |
18 00 FF 00 |
58 00 (no codes) or 58 01 9A 31 20 (one code) |
Read DTCs by status. 9A 31 is B1A31, "Left front tire pressure low" (confirmed by SZ Viewer). SZ Viewer shows status 20 as History (stored, not current); E0 was seen in earlier captures
21 00 |
61 00 + 100 bytes |
Sensor data block (repeated about twice a second by the Launch tool, every 0.12 to 0.15 s by SZ Viewer) |
Part labels on the test car: TPMS controller 37160-78R00, "BASE ASSY-TPMS", Model No. P61M0, Continental A2C13930301, 433.92 MHz; central gateway controller 33580-79R01. The 1A 8E reply (37160-61M0) matches the TPMS controller's base number and model number; the 1A 8A reply (37120-78R0*) shares "78R0" with the full part number, but its meaning is not confirmed.
A Launch full scan reported "Left Front Tire Pressure Low" for the TPMS module, and the module returned one stored code (9A 31) in the same scan. SZ Viewer decodes that code as B1A31, "Left front tire pressure low", stored as History.
Reading it with an ELM327
Terminal commands, one at a time (CR line ending):
ATZ ATSP6 ATSH798 ATS0 ATL0 ATFCSH798 ATFCSD300000 ATFCSM1 2100
ATSH798sets the request address. The reply address (0x7A8) is worked out automatically.ATFCSH798 / ATFCSD300000 / ATFCSM1make the adapter send the ISO-TP flow-control frame (30 00 00) itself.ATS0removes the spaces between bytes. Without it, the generic Chinese ELM327-based dongle (dongle 1) reportedBUFFER FULLnear byte 81.- Expected output: a length line (
066= 102 bytes) and numbered lines0:toE:. - With default settings dongle 1 returned only the first line (
61 00 xx 01 00 00).
Reply layout (21 00)
Byte positions count the 61 as byte 0. The letter is the variable name used by Torque Pro, Car Scanner and RealDash (A = byte 2). This is a summary; the full decode, with example values checked against SZ Viewer, is in Sensor data block (21 00) layout.
| Bytes | Letters | Content |
| 0-1 | – | 61 00 (positive reply)
| 2 | A | Module supply voltage: V = A / 10 (confirmed against SZ Viewer) |
| 3-11 | B-J | Not decoded (byte 3 was 01, the rest zero so far)
| 12-21 | K-T | Sensor record 1 |
| 22-31 | U-AD | Sensor record 2 |
| 32-41 | AE-AN | Sensor record 3 |
| 42-51 | AO-AX | Sensor record 4 |
| 52-71 | AY-BR | Five 4-byte sensor ID slots, probably a log of recently received sensors (inferred) |
| 72-75 | BS-BV | Low-pressure warning threshold, one per wheel in wheel-position order (right front, left front, right rear, left rear), x 0.0137 bar. Temperature-compensated. The lamp came on when the left front pressure fell below byte 73 |
| 76-79 | BW-BZ | One value per wheel, x 0.0137 bar. Possibly the threshold at which the warning clears (inferred) |
| 80-81 | CA-CB | Not decoded |
| 82-83 | CC-CD | Vehicle speed: km/h = (CC x 256 + CD) / 128, or simply CC x 2 (confirmed against SZ Viewer while driving) |
| 84-91 | CE-CL | Four counters, probably ABS wheel-rotation counts (inferred) |
| 92 | CM | Low tyre pressure warning lamp: on when bit 7 is set, so CM of 128 or more means the lamp is on (confirmed against SZ Viewer) |
| 93-101 | CN-CV | Not decoded |
Sensor record (10 bytes)
| Offset | Letters (records 1 / 2 / 3 / 4) | Content | Formula |
| +0 to +3 | K-N / U-X / AE-AH / AO-AR | Sensor ID | 4 bytes, hex |
| +4 | O / Y / AI / AS | Wheel position, learned by the module's auto-location, in the top five bits. The bottom three bits are status flags that get set once the car has been driven (for example 10 becomes 14, then 15) |
Whole-number part of value / 8: 1 = right front, 2 = left front, 3 = right rear, 4 = left rear. Plain value / 8 gives fractions such as 2.625 after driving |
| +5 | P / Z / AJ / AT | Air temperature | °C = value − 50 |
| +6 | Q / AA / AK / AU | Air pressure, gauge (see Calibration) | bar = value x 0.01372 |
| +7 | R / AB / AL / AV | Rotational (centripetal) acceleration, held from the sensor's last transmission | g = value / 2 |
| +8 | S / AC / AM / AW | Sensor status (SZ Viewer calls it battery status) | 42 = Normal, seen on every sensor while driving. 49 and 4C appear in data held from parking, 82 was seen once, and 4A was sent while the tyre was being let down; probably a sensor mode as well as the battery state
| +9 | T / AD / AN / AX | Unknown | Always 0 so far |
The records are not in wheel order. The module keeps them in its own order (the decode page says sensor-ID order) and reports the wheel in byte +4. On the test car the order is front left, rear left, rear right, front right, which is what the app setups below assume. After tyres are rotated or a sensor is replaced, the record that holds each wheel can change: check the position bytes (O, Y, AI, AS; the wheel is the whole-number part of the value divided by 8) and swap the letters in the app setups to match.
| Record | Wheel | Sensor ID | Byte +4 (parked) | Position (whole number of value / 8) |
| 1 | Front left | 4E AA 09 43 | 0x10 | 2 |
| 2 | Rear left | DD 91 B5 25 | 0x20 | 4 |
| 3 | Rear right | 4E AA 03 19 | 0x18 | 3 |
| 4 | Front right | 4E AA 09 C9 | 0x08 | 1 |
Sensor IDs are specific to one car. Yours will differ.
Calibration
Byte +6 against gauge readings (bar). The five deflation-test counts were reconstructed from the app's displayed values.
| Raw | Gauge (bar) | Raw x 0.01372 |
| 136 (rear left) | 1.868 | 1.866 |
| 131 (rear right) | 1.795 | 1.797 |
| 131 (front right) | 1.795 | 1.797 |
| 126 | 1.73 | 1.729 |
| 119 | 1.63 | 1.633 |
| 112 | 1.54 | 1.537 |
| 101 | 1.39 | 1.386 |
| 96 | 1.29 | 1.317 |
The last five rows are from one tyre, the front left, during a slow deflation.
- bar = raw x 0.01372
- psi = raw x 0.199
- kPa = raw x 1.372
No offset is needed, which suggests the byte holds gauge pressure. All points are within 0.004 bar except the lowest (0.027 bar off), which may be sensor update lag or slight non-linearity.
The SZ Viewer app scales the same byte by exactly 0.0137 bar per count (psi x 0.1987, kPa x 1.37); all four of its displayed values match that to three decimals. The two factors give the same reading to two decimal places, so either can be used. Use *0.0137 if you want the app to agree exactly with SZ Viewer.
Torque Pro custom PIDs
Common fields for every wheel:
| Field | Value |
| Header | 798 |
| Mode and PID | 2100 |
| Diagnostic start command | ATS0, ATL0, ATFCSH798, ATFCSD300000, ATFCSM1 (comma-separated)
| Unit / min / max | bar, 0, 4 (or psi, 0, 60) |
Equation uses a letter for each data byte. A is the first byte after 61 00 (reply byte 2). Letters for the test car's record order:
| Wheel | Record | Position (byte +4) | Temperature (byte +5) | Pressure (byte +6) |
| Front left | 1 | O | P | Q |
| Front right | 4 | AS | AT | AU |
| Rear left | 2 | Y | Z | AA |
| Rear right | 3 | AI | AJ | AK |
Examples: pressure Q*0.01372 (bar); temperature P-50 (°C); position O/8 (read only the whole number: 2.625 means 2, see Sensor record); module supply voltage A/10 (V). Letters must be upper case. Whether Torque accepts two-letter variables is unconfirmed.
Known problem
Using dongle 1 (generic Chinese ELM327-based) with Torque Pro on a Lenovo tablet, Torque read bytes A to D (first line of the reply) correctly, but every byte from E onward returned -1, even though a terminal received the full 102 bytes with the same commands. The start-command field is applied (adding ATH1 changed the output). Tried without success: turning off "Faster communication" and removing ATS0. Not tried: ATAT0, ATSTFF timeout settings.
Dongle 2 (Veepeak OBDCheck BLE+), also on the tablet, gave the same result. Car Scanner Pro reads every byte with both dongles and the same commands, so the limitation is in how Torque Pro handles this multi-line reply, not in the adapter or the Android device. Unresolved; a request has been posted on the Torque forum.
Car Scanner Pro (working)
Car Scanner Pro reads all the bytes where Torque Pro fails. Custom PID settings used:
- Header: 798
- Request: 2100
- Start command (backslash-separated):
ATAT0\ATSTFF\ATS0\ATL0\ATFCSH798\ATFCSD300000\ATFCSM1 - Equations use the same letters as the table above, for example
Q*0.01372for front left (bar)
The pressure PIDs are tested. The PIDs below use the same header, request and start command and follow the decode, but have not yet been tried in the app (untested):
| PID | Equation | Unit | Min / max |
| TPMS module voltage | A/10 |
V | 0 / 16 |
| Temperature front left | P-50 |
°C | -40 / 120 |
| Temperature front right | AT-50 |
°C | -40 / 120 |
| Temperature rear left | Z-50 |
°C | -40 / 120 |
| Temperature rear right | AJ-50 |
°C | -40 / 120 |
| Record 1 position | O/8 |
– | 1 / 5 |
| Record 2 position | Y/8 |
– | 1 / 5 |
| Record 3 position | AI/8 |
– | 1 / 5 |
| Record 4 position | AS/8 |
– | 1 / 5 |
Position values: 1 = right front, 2 = left front, 3 = right rear, 4 = left rear. After the car has been driven the value has a fraction (for example 2.625), because the module sets status bits in the low part of the byte; the whole number is still the wheel. Set the PID to show no decimal places only if the app truncates rather than rounds (2.625 rounds to 3, which would be wrong). If a record's position no longer matches the wheel in its PID name, swap the letters (see Sensor record).
The start command has not yet been shortened. Both dongle 1 (generic ELM327-based) and dongle 2 (Veepeak OBDCheck BLE+) work with Car Scanner Pro on the Lenovo tablet. Dongle 2 will not connect to the XTRONS head unit.
RealDash
RealDash describes its OBD2 communication in an XML file. With dongle 1, RealDash's default init plus the lines below works: the TPMS sensors reply, and the values appear in RealDash's debug view. Dashboard gauges are in progress.
Changes to RealDash's default file:
- Add the three flow-control commands to the init section, before the
0100and0120checks. - Every TPMS command sets
header="atsh798". The docs say to set the header on every command when the rotation uses more than one. Any standard command in the same rotation then needsheader="atsh7df", or it would be sent to 0x798. - RealDash requires
ATE0,ATL0andATS0(already in its default init).
<init> ... RealDash default init lines ... <command send="atfcsh798"></command> <command send="atfcsd300000"></command> <command send="atfcsm1"></command> <command send="0100"></command> <command send="0120"></command> </init> <rotation> <command send="2100" header="atsh798" skipCount="10" keepInRotation="true" name="TPMS: front left" units="bar" conversionABC="Q*0.01372"></command> <command send="2100" header="atsh798" skipCount="11" keepInRotation="true" name="TPMS: front right" units="bar" conversionABC="AU*0.01372"></command> <command send="2100" header="atsh798" skipCount="12" keepInRotation="true" name="TPMS: rear left" units="bar" conversionABC="AA*0.01372"></command> <command send="2100" header="atsh798" skipCount="13" keepInRotation="true" name="TPMS: rear right" units="bar" conversionABC="AK*0.01372"></command> </rotation>
conversionABC uses the same letters as Torque and Car Scanner (A is the first byte after 61 00). The TPMS inputs appear in RealDash's ECU Specific category. The letters assume the test car's record order; see Sensor record if the tyres have been rotated.
Optional extra inputs (untested): the same pattern should give tyre temperatures and the module voltage. They change slowly, so a higher skipCount is used to poll them less often:
<command send="2100" header="atsh798" skipCount="40" keepInRotation="true" name="TPMS: temp front left" units="C" conversionABC="P-50"></command> <command send="2100" header="atsh798" skipCount="41" keepInRotation="true" name="TPMS: temp front right" units="C" conversionABC="AT-50"></command> <command send="2100" header="atsh798" skipCount="42" keepInRotation="true" name="TPMS: temp rear left" units="C" conversionABC="Z-50"></command> <command send="2100" header="atsh798" skipCount="43" keepInRotation="true" name="TPMS: temp rear right" units="C" conversionABC="AJ-50"></command> <command send="2100" header="atsh798" skipCount="44" keepInRotation="true" name="TPMS: module voltage" units="V" conversionABC="A/10"></command>
The Veepeak OBDCheck BLE+ (dongle 2) will not connect to the head unit because the head unit does not support BLE, so only dongle 1 was used.
4WD status (0x772)
The 4WD shift controller answers UDS 22 10 00 on request ID 0x772, reply ID 0x782, with 30 data bytes. It shows which drive mode is selected and what the actuator is doing. Reading the switch byte (V) has been tested in RealDash with dongle 1, and its values matched the SZ Viewer captures below. The terminal commands, the Car Scanner settings and the other inputs are untested. The full decode is in 4WD data (22 10 00) layout.
ATZ ATSP6 ATSH772 ATS0 ATL0 ATFCSH772 ATFCSD300000 ATFCSM1 221000
ATFCSH772is needed: the reply comes from 0x782, and the adapter's own flow-control frame would otherwise go to the wrong ID (0x77A), so the module would send only the first frame.- The RealDash test also sent
ATCRA782(accept replies from 0x782 only). Whether this module needs it has not been checked; the ABS module does need the equivalent command. - Expected output: a length line (
021= 33 bytes) and numbered lines0:to4:, starting621000.
Reply layout (22 10 00)
Byte positions count the 62 as byte 0. With a two-byte request (10 00) the apps' letter A is the first byte after 62 10 00, so A = byte 3.
| Byte | Letter | Content |
| 0-2 | – | 62 10 00 (positive reply)
| 3 | A | Module supply voltage: V = A / 10 (confirmed against SZ Viewer) |
| 5 | C | Vehicle speed, km/h (inferred, 0 km/h only) |
| 23 | U | Engine running (1) or off (0) |
| 24 | V | Switches and valves: bit 0 = 4WD switch, bit 1 = 4WD-L switch, bit 2 = vacuum switch, bit 4 = VSV1 (unlocks the hubs), bit 5 = VSV2 (locks the hubs). Bit 7 is always set |
| 28 | Z | Result: bit 0 = 4WD indicator (hubs confirmed locked), bit 1 = hubs not confirmed (fault), bit 3 = 4WD switch, bit 4 = A/C cut (set while a valve is open) |
Read as whole numbers (no bit functions needed), bytes V and Z gave these values while shifting:
| State | V (byte 24) | Z (byte 28) |
| 2H | 128 (80) |
4 (04)
| Shifting 2H to 4H (actuator working) | 161, then 165 (A1, A5) |
24, then 25 (18, 19)
| 4L, while shifting | 167 (A7) |
29 (1D)
| 4L | 135, then 131 (87, 83) |
13 (0D)
| 4H | 129 (81) |
9 (09)
| Shifting 4H to 2H (actuator working) | 144 (90) |
21, then 20 (15, 14)
So for a simple gauge: V = 128 is 2H, V = 129 is 4H, V = 131 or 135 is 4L, and anything else means the actuator is moving.
RealDash on the test car showed the same values for V: 128 in 2H, 129 in 4H (165 while shifting), 131 in 4L (167 while shifting) and 144 while shifting back to 2H.
Car Scanner Pro
Custom PID settings (untested):
- Header: 772
- Request: 221000
ATAT0\ATSTFF\ATS0\ATL0\ATFCSH772\ATFCSD300000\ATFCSM1
| 4WD switch byte | V |
– | 128 / 167 |
| 4WD actuator byte | Z |
– | 0 / 31 |
| 4WD module voltage | A/10 |
V | 0 / 16 |
The start command sets the flow-control header to 772. The TPMS PIDs need their own start command with ATFCSH798. Whether Car Scanner can read both modules in one session has not been tested; see Reading more than one module.
RealDash
Same pattern as the TPMS file, with the flow-control header for 0x772. The switch byte input has been tested; the actuator byte and voltage inputs have not:
<init> ... RealDash default init lines ... <command send="atfcsh772"></command> <command send="atfcsd300000"></command> <command send="atfcsm1"></command> <command send="0100"></command> <command send="0120"></command> <command send="atcra782"></command> </init> <rotation> <command send="221000" header="atsh772" skipCount="5" keepInRotation="true" name="4WD: switch byte" conversionABC="V"></command> <command send="221000" header="atsh772" skipCount="6" keepInRotation="true" name="4WD: actuator byte" conversionABC="Z"></command> <command send="221000" header="atsh772" skipCount="40" keepInRotation="true" name="4WD: module voltage" units="V" conversionABC="A/10"></command> </rotation>
- A RealDash gauge can map the switch byte to text: 128 = 2H, 129 = 4H, 131 or 135 = 4L.
- Single flags can be read as on/off inputs; see Dashboard lamps below.
- Give every input its own
skipCount. In a test where the V and Z inputs both usedskipCount="1", only V showed a value; the shared skipCount is the suspected cause (not yet confirmed). - With an ELM327 this file reads only the 4WD controller; see Reading more than one module.
Before loading a new description file, clear RealDash's imported inputs. RealDash keeps the inputs from every file it has loaded. The Jimny test files all use the same input names, so a lamp or gauge can stay linked to a stale copy from an earlier file that never updates. In the first tests this made the VSV2 and VACUUM lamps stay off and byte Z read 0, although byte V and the 4WD, LOW and VSV1 lamps worked. The method below is the one given by the RealDash developer on the RealDash forum:
- Settings → Units & Values → Imported Values. Tap and hold the top of the list to select all (or select the old entries), and delete them.
- Select only the new file in the connection settings, then restart RealDash or reconnect, so only that file's inputs are imported.
- Re-link every lamp or gauge that used a deleted input, picking it from the fresh list.
Dashboard lamps (4WD, LOW, VSV1, VSV2, VACUUM)
A word on the RealDash screen that is grey when off and turns green when on, one for each state. The inputs below pick out single bits with % (remainder) and a comparison, which give 1 or 0. Both work in RealDash conversions (tested with the steering angle), while &, >> and ?: do not. The 4WD lamps with these inputs were tested on the car on 28 November 2026 (see the test result below the table).
Inputs. Each lamp needs one bit as an on/off (0 or 1) input. For a bit with value n (1, 2, 4, 8, 16 or 32) the test is (V%(2n)>(n-1)): for example bit 2 (value 4) is (V%8>3). Add these to the <rotation> of the 4WD file above, each with its own skipCount:
<command send="221000" header="atsh772" skipCount="2" keepInRotation="true" name="4WD: 4WD" units="bit" conversionABC="(V%2>0)"></command> <command send="221000" header="atsh772" skipCount="3" keepInRotation="true" name="4WD: LOW" units="bit" conversionABC="(V%4>1)"></command> <command send="221000" header="atsh772" skipCount="4" keepInRotation="true" name="4WD: VSV1" units="bit" conversionABC="(V%32>15)"></command> <command send="221000" header="atsh772" skipCount="7" keepInRotation="true" name="4WD: VSV2" units="bit" conversionABC="(V%64>31)"></command> <command send="221000" header="atsh772" skipCount="8" keepInRotation="true" name="4WD: vacuum switch" units="bit" conversionABC="(V%8>3)"></command> <command send="221000" header="atsh772" skipCount="9" keepInRotation="true" name="4WD: indicator (hubs locked)" units="bit" conversionABC="(Z%2>0)"></command> <command send="221000" header="atsh772" skipCount="10" keepInRotation="true" name="4WD: hub fault" units="bit" conversionABC="(Z%4>1)"></command> <command send="221000" header="atsh772" skipCount="11" keepInRotation="true" name="4WD: A/C cut" units="bit" conversionABC="(Z%32>15)"></command>
- Earlier versions used bitwise operators (
V&1,(V>>1)&1), then division withunits="bit"(V/2,V/16,V/32). Neither reliably gave single bits; the%method above replaces them. - Check the inputs with text gauges first (each should read 0 or 1 as in the table below), then switch to the image lamps.
| Input | Bit | Lit when |
| 4WD: 4WD | V bit 0 | 4H or 4L selected (follows the lever) |
| 4WD: LOW | V bit 1 | 4L selected |
| 4WD: VSV1 | V bit 4 | The hubs are unlocking: about 10 s after selecting 2H |
| 4WD: VSV2 | V bit 5 | The hubs are locking: from selecting 4WD until about 5 s after the vacuum switch comes on (about 11 to 13 s if it never does) |
| 4WD: vacuum switch | V bit 2 | Vacuum has reached the hub locking side, while VSV2 is open |
| 4WD: indicator (hubs locked) | Z bit 0 | The hubs are confirmed locked, until the lever leaves 4WD (like the dash 4WD light) |
| 4WD: hub fault | Z bit 1 | VSV2 gave up without the vacuum switch confirming (no vacuum, hose off or switch unplugged) |
| 4WD: A/C cut | Z bit 4 | VSV1 or VSV2 is open |
- Test result, 28 November 2026. A file reading only the 4WD controller (the inputs above plus the raw bytes V and Z, each with its own skipCount from 1 to 9), loaded after clearing the imported inputs: every input worked. V went through its intermediate values while shifting, VSV2 and VACUUM lit while the hubs locked, and the indicator (Z bit 0) lit in 4H. Whether VSV2 and VACUUM still catch the short lock pulse when the 4WD inputs are read less often, in the all-modules file, is not yet tested.
- The vacuum switch and VSV2 were first thought to share one bit. Captures on 28 November 2026 with the vacuum hose off and with the vacuum switch unplugged separated them: VSV2 still opened, but bit 2 never came on. In normal running bit 2 follows VSV2 about 0.3 s later. The full decode is in 4WD data (22 10 00) layout.
- For a 4WD lamp that lights only once the hubs are locked, like the dash light, use 4WD: indicator. 4WD: hub fault suits a red warning lamp.
- If the bit inputs do not work, the 4WD lamp can use the whole switch byte,
conversionABC="V", with Range 128 to 167 and Warning Level 128 to 128.5, so any value other than 128 (2H) lights it. It then also stays lit for about 10 s while the box shifts back to 2H (144). LOW has no simple whole-number test (it is 131, 135 or 167).
Images. Use a PNG of each word, white text on a transparent background (512 × 200 pixels works). White takes the tint colour exactly, so the gauge colours below appear as set. RealDash accepts PNG (and GIF, animated PNG and, from 2.7.3, WebP). White rounded-corner frames made the same way can be used to group the lamps.
The images used on the test car (click one to open its file page and download it; they are white, so they are shown here on a dark background):
Gauges. For each lamp:
- Add Gauge → Image. In Look'n Feel → Images → Background Image, pick the word's PNG.
- In Input & Values, choose ECU Specific and the matching input. Set Range 0 to 1 and Warning Level 0 to 0.5, so a value of 1 is above the warning maximum and puts the gauge in its Warning level.
- In Look'n Feel → Colors → Image Blend Color, set Editing Level Normal to grey (RGB 128, 128, 128) and Editing Level Warning to green (RGB 0, 200, 0).
To check the colours without a data feed, temporarily set the Warning Level to 0.5 to 1: with no data the input reads 0, which is below the warning minimum, so the gauge should show its Warning colour. Set it back to 0 to 0.5 afterwards.
Annunciator panel
An alternative to the tinted words above: a brushed aluminium panel with five lamp windows, and a lit and an unlit image for each lamp. The images were drawn for this project. Click one to open its file page and download it.
Panel:
640 × 470 pixels, transparent outside the rounded corners.
- VSV2 and VACUUM have separate inputs. In normal running VACUUM lights about 0.3 s after VSV2; if VSV2 lights without VACUUM, the hubs are not getting vacuum.
- The positions are the top-left corner of each lamp window on the full-size panel. If the panel is scaled in RealDash, scale the positions and sizes with it.
Setting it up (untested). This follows the method in the RealDash manual's "Make an indicator" page: an Image gauge whose Normal level is made invisible with the Image Blend Color opacity, so it only shows at its Warning level.
- Add the panel: Add Gauge → Image, with the panel PNG as its Background Image (Look'n Feel → Images) and no input. Keep it behind everything else.
- For each window, add Gauge → Image the same size as the window, with the unlit PNG as its Background Image and no input. This is always shown.
- On top of it, add another Gauge → Image the same size and position, with the lit PNG as its Background Image.
- In that lit gauge's Input & Values, choose ECU Specific and the input from the table. Set Range 0 to 1 and Warning Level 0 to 0.5, as for the word lamps.
- In its Look'n Feel → Colors → Image Blend Color, set the Normal level to opacity 0 (invisible) and the Warning level to white (RGB 255, 255, 255) at full opacity.
When the input is 0 the lit image is invisible and the unlit lamp shows through; when it is 1 the lit image covers it.
- The 4WD lamp inputs have been tested on the car (see the test result above). This panel's set-up steps are still untested; the lamps can be checked with the colour test described there.
Six-lamp panel
A version of the annunciator panel with a sixth window, so that a failed hub lock has its own warning lamp. The VACUUM lamp is low-key: black glass with green lettering that glows when the vacuum switch is on. The red NO VACUUM lamp is the only one that means something is wrong. The images were drawn for this project; click one to open its file page and download it.
All lamps off; normal, just after 4WD is selected (4WD, VSV2 and VACUUM lit); fault, no vacuum (4WD, VSV2 and NO VACUUM lit).
Panel:
640 × 470 pixels, six windows of 260 × 110 in three rows of two, transparent outside the rounded corners.
- All six lamps are 260 × 110 pixels. Set them up as described for the five-lamp panel above: the unlit image underneath, the lit image on top with Range 0 to 1 and Warning Level 0 to 0.5.
- What to expect:
- Selecting 4WD in normal operation: 4WD lights, then VSV2, then VACUUM a moment later. VSV2 and VACUUM go out about 5 s after that. VACUUM being off at other times is normal; the switch only reports while VSV2 is open.
- Going back to 2H: 4WD goes out and VSV1 lights for about 10 s.
- No vacuum (engine off, vacuum hose off or vacuum switch unplugged): VACUUM never lights. NO VACUUM comes on and stays lit until the lever is moved again.
- Do not invert the VACUUM input to make a "no vacuum" lamp: it would be lit nearly all the time. The controller's own result (Z bit 1) is the right signal for a fault.
- Tested on the car on 28 November 2026 with the 4WD-only file: 4WD, LOW, VSV1, VSV2, VACUUM and the indicator worked. The NO VACUUM (fault) case has not yet been checked in RealDash.
ABS wheel speeds (0x261)
The ABS/ESP module answers KWP 21 00 on request ID 0x261, reply ID 0x661, with a 52-byte data block that includes all four wheel speeds. Tested with dongle 1: the terminal commands below return the full block, and RealDash showed the front right wheel speed. The other RealDash inputs and the Car Scanner settings are untested. The full decode, including acceleration, yaw rate, steering angle and brake pressure, is in ABS data block (21 00) layout.
ATZ ATSP6 ATSH261 ATCRA661 ATS0 ATL0 ATFCSH261 ATFCSD300000 ATFCSM1 2100
ATFCSH261is needed: the reply comes from 0x661, and the adapter's own flow-control frame would otherwise go to the wrong ID, so the module would send only the first frame.ATCRA661is needed: without it the adapter ignored the replies from 0x661, and RealDash received no data until it was added. The TPMS module (reply 0x7A8) works without it.- Expected output: a length line (
034= 52 bytes) and numbered lines0:to7:, starting6100.
Wheel speeds in the reply
Byte positions count the 61 as byte 0; letter A is the first byte after 61 00 (A = byte 2).
| Byte | Letter | Wheel | Formula |
| 9 | H | Front right | H km/h |
| 10 | I | Front left | I km/h |
| 11 | J | Rear right | J km/h |
| 12 | K | Rear left | K km/h |
The speeds are whole km/h and matched SZ Viewer in the drive captures (for example 8, 11, 7 and 10 km/h in a tight right turn).
Car Scanner Pro
- Header: 261
- Request: 2100
ATAT0\ATSTFF\ATS0\ATL0\ATCRA661\ATFCSH261\ATFCSD300000\ATFCSM1
| Wheel speed front right | H |
km/h | 0 / 200 |
| Wheel speed front left | I |
km/h | 0 / 200 |
| Wheel speed rear right | J |
km/h | 0 / 200 |
| Wheel speed rear left | K |
km/h | 0 / 200 |
RealDash
Same pattern as the TPMS and 4WD files, with the flow-control header for 0x261 and the receive address 0x661. Tested with the front right wheel speed; the other three inputs use the same request but are untested:
<init> ... RealDash default init lines ... <command send="atfcsh261"></command> <command send="atfcsd300000"></command> <command send="atfcsm1"></command> <command send="0100"></command> <command send="0120"></command> <command send="atcra661"></command> </init> <rotation> <command send="2100" header="atsh261" skipCount="1" keepInRotation="true" name="ABS: wheel speed front right" units="km/h" conversionABC="H"></command> <command send="2100" header="atsh261" skipCount="2" keepInRotation="true" name="ABS: wheel speed front left" units="km/h" conversionABC="I"></command> <command send="2100" header="atsh261" skipCount="3" keepInRotation="true" name="ABS: wheel speed rear right" units="km/h" conversionABC="J"></command> <command send="2100" header="atsh261" skipCount="4" keepInRotation="true" name="ABS: wheel speed rear left" units="km/h" conversionABC="K"></command> </rotation>
- Each input is a separate
2100request, so four inputs mean four requests per round. Give each its ownskipCount(see the 4WD section) and raise them if other values become slow. atcra661comes after the0100and0120checks, as in the tested file, because those checks expect the normal engine replies.- With an ELM327 this file reads only the ABS module; see Reading more than one module.
Wheel slip display
Untested: four bars, one beside each wheel on a top-down outline of the car, so a spinning wheel's bar stands out.
Inputs. Each wheel's speed minus the average of all four. With grip, all four read near 0 at any speed; a spinning wheel's bar rises and the others dip slightly. Add to the ABS file above:
<command send="2100" header="atsh261" skipCount="8" keepInRotation="true" name="ABS: slip front right" units="km/h" conversionABC="H-(H+I+J+K)/4"></command> <command send="2100" header="atsh261" skipCount="9" keepInRotation="true" name="ABS: slip front left" units="km/h" conversionABC="I-(H+I+J+K)/4"></command> <command send="2100" header="atsh261" skipCount="10" keepInRotation="true" name="ABS: slip rear right" units="km/h" conversionABC="J-(H+I+J+K)/4"></command> <command send="2100" header="atsh261" skipCount="11" keepInRotation="true" name="ABS: slip rear left" units="km/h" conversionABC="K-(H+I+J+K)/4"></command>
- Showing the difference rather than the raw speed makes slip easy to see: at 60 km/h a wheel spinning 5 km/h faster is only about 4% taller on a 0 to 140 km/h bar, but fills half of a 0 to 10 km/h bar.
- Bar range −10 to +10 km/h, or 0 to 10 to show only spin.
- In tight corners the outside wheels read 1 to 2 km/h high; that is normal, not slip.
- If all four wheels spin together (possible in 4WD), the differences stay near 0. Only the raw wheel speeds show that case.
- The wheel speeds are whole km/h, so small differences come in steps.
Background image (white on a transparent background, shown here on a dark background; click it to open its file page):
- 453 × 800 pixels, engine at the top. Drawn for this project from the car's published length, width and wheelbase.
- Add it as an Image gauge (Add Gauge → Image) with no input, behind the bars, with Image Blend Color white or any tint.
- Place one vertical bar gauge beside each wheel, inside the body outline, with its input from the list above. Each tyre is about 42 × 133 pixels, so a bar about 130 pixels tall matches it. Wheel centres at full size:
| Wheel | Centre (x, y) |
| Front left | 77, 189 |
| Front right | 376, 189 |
| Rear left | 77, 613 |
| Rear right | 376, 613 |
- Bezel (optional): a slim brushed aluminium frame matching the annunciator panel, 521 × 868 pixels, transparent in the middle. Add it as an Image gauge with no input, on top of the plan and the bars, with Image Blend Color white (255, 255, 255) so the metal keeps its colours. At full size the plan sits at 34, 34 inside it, so the wheel centres measured on the bezel are 111, 223 and 410, 223 (front) and 111, 647 and 410, 647 (rear). If it is scaled, scale the plan, bars and bezel together.
Brake and ESP lamps
Inputs for lamps that show what the ABS/ESP is doing at each wheel, and an ESP OFF lamp. They come from Launch X431 output tests on 28 November 2026 (each wheel braked in turn, then ESP off and on), matched against the earlier driving capture. The byte meanings are in ABS data block (21 00) layout. Not yet tested in RealDash.
- Byte AR holds two bits per wheel: front right bits 0–1, front left 2–3, rear right 4–5, rear left 6–7. Both bits clear means the wheel is open to brake pressure as normal; any bit set means the ABS is holding or releasing that wheel's pressure.
- Bit 6 of byte AS is set while the module builds brake pressure itself (its pump). A wheel that is still open at that moment is the one being braked, which is how ESP and traction control brake a single wheel. In the output tests this picked out the tested wheel every time; whether traction control on the road sets the same bit is untested.
- Bit 2 of byte AQ is set while ESP is switched off.
| Input | Formula | Lit when |
| ABS: ESP off | (AQ%8>3) |
ESP is switched off |
| ABS: valve front right | (AR%4>0) |
ABS or EBD is holding or releasing the front right brake |
| ABS: valve front left | (AR%16>3) |
The same, front left |
| ABS: valve rear right | (AR%64>15) |
The same, rear right (both rear lamps light in any hard stop: EBD) |
| ABS: valve rear left | (AR>63) |
The same, rear left |
| ESP: braking front right | (AS%128>63)*(1-(AR%4>0)) |
The system is braking the front right wheel on its own |
| ESP: braking front left | (AS%128>63)*(1-(AR%16>3)) |
| ESP: braking rear right | (AS%128>63)*(1-(AR%64>15)) |
The same, rear right |
| ESP: braking rear left | (AS%128>63)*(1-(AR>63)) |
- The formulas use only
%,>,*and-. A<cannot be written inside the XML attribute, so "wheel open" is written as1-(...). - Example lines for the
<rotation>(each input needs its own skipCount, or its own spelling of the request):
<command send="2100" header="atsh261" skipCount="13" keepInRotation="true" name="ABS: ESP off" units="bit" conversionABC="(AQ%8>3)"></command> <command send="2100" header="atsh261" skipCount="14" keepInRotation="true" name="ABS: valve front right" units="bit" conversionABC="(AR%4>0)"></command> <command send="2100" header="atsh261" skipCount="18" keepInRotation="true" name="ESP: braking front right" units="bit" conversionABC="(AS%128>63)*(1-(AR%4>0))"></command>
- Set the lamps up like the 4WD lamps: Range 0 to 1, Warning Level 0 to 0.5.
- During a Launch output test the "valve" lamps show the opposite of what is happening (the three wheels that are not being tested are held), while the "braking" lamp shows the tested wheel.
ABS and ESP panels
Two brushed aluminium panels with the name engraved across the top, each with four wheel lamps, and an ESP OFF lamp to match the annunciator lamps. The images were drawn for this project; click one to open its file page and download it.
ABS panel in a hard stop (both rear wheels held); ESP panel while ESP brakes the front right wheel; ESP OFF lit and unlit.
Panels:
640 × 340 pixels, four windows of 260 × 110 under a 50-pixel top border (the same as the 4WD panels), transparent outside the rounded corners. Unlit previews:
- Both panels use the same four amber wheel lamps (260 × 110). The ESP OFF lamp (260 × 110, amber) uses the input ABS: ESP off.
- ESP OFF frame:
a slim brushed aluminium frame for the ESP OFF lamp on its own, 360 × 180 pixels, with one 260 × 110 window at 50, 35. Set the lamp up in it the same way. - Set each lamp up as for the annunciator panel: the unlit image underneath, the lit image on top with Range 0 to 1 and Warning Level 0 to 0.5.
- What to expect: both rear lamps on the ABS panel light in any hard stop; a front lamp joins them if that wheel locks and the ABS cuts in. The ESP panel lights a wheel only while ESP or traction control brakes it on its own (untested on the road). ESP OFF follows the dash ESP OFF light.
- Untested in RealDash on the car.
Pitch and roll (bubble level)
Untested: this needs a parked test on a known slope before it can be relied on.
The ABS data block has a longitudinal acceleration byte (L, byte 13) and a lateral acceleration byte (S, byte 20), both centred on 128 at 0.02 g per count, and both checked against SZ Viewer while driving. Acceleration sensors normally also read gravity: parked on a slope, the share of gravity along each sensor is the sine of the angle (0.17 g = 10°, 0.34 g = 20°, 0.5 g = 30°). If the ESP module reports the raw sensor values, these two bytes give pitch and roll at about 1.1° per count. The sensors are fixed level in the car, so unlike the tablet's own accelerometer they need no mounting calibration.
Inputs. Add to the ABS file above:
<command send="2100" header="atsh261" skipCount="5" keepInRotation="true" name="ABS: pitch" units="deg" conversionABC="(L-128)*1.15"></command> <command send="2100" header="atsh261" skipCount="6" keepInRotation="true" name="ABS: roll" units="deg" conversionABC="(S-128)*1.15"></command>
- The result is in degrees, about 1.15° per count. This is a straight-line approximation of the true (arcsine) angle and is close up to about 30°.
- Only plain arithmetic is used. Functions such as
asin,maxandminare documented for RealDash CAN files, not for OBD2 conversions. - Only accurate when stopped or crawling: accelerating reads as nose-up and braking as nose-down, as with any accelerometer.
Slope test. Park nose-up on a slope of known angle with the engine running:
ABS: pitchshould show roughly the slope angle, and be positive. If it is negative, change(L-128)to(128-L).- Park across the slope one way and then the other;
ABS: rollshould change sign. Choose its sign so that the bubble moves the way you want. - If either stays at 0, read the raw byte with
conversionABC="L". If L stays at 128 on a slope, the ESP module removes gravity from its readings and this method does not work; the tablet's own accelerometer would be the fallback (RealDash's DEVICE inputs Acceleration X, Y and Z, which follow the tablet's mounting and cannot be zeroed in RealDash).
Display. RealDash has no inclinometer gauge, but its Axis gauge (Add Gauge → Indicators → Axis gauge, from the RealDash forum) moves an image in two directions from two inputs, which makes a bubble level:
- Input & Values: X =
ABS: roll, Y =ABS: pitch, both with the range −45 to +45, so the rings on the face line up with the angles. - Look'n Feel: the face below as the gauge face and the dot (or the Jimny) as the indicator. Some value smoothing stops it jittering.
- Tint with Image Blend Color as for the lamps, for example the face grey and the indicator green, changing at a Warning level for steep angles.
The Axis gauge moves the indicator but does not rotate it, so the Jimny does not lean as the car rolls; its position on the face shows the angle.
Images (white on a transparent background, shown here on a dark background; click one to open its file page):
- Face: 800 × 800 pixels, rings at 10°, 20°, 30° and 40°, outer edge at 45° (8 pixels per degree), NOSE UP at the top.
- Horizon face: the same face with a light blue sky above and light green ground below, like an artificial horizon (the colours are fixed; the bubble moves over them). Set its Image Blend Color to white (255, 255, 255) so the colours are kept.
- Indicators: a plain dot (96 × 96) or a rear view of a Jimny (160 × 140; the body is white for tinting and the details are solid black so the rings do not show through).
- Bezel ring (optional): a spun (brushed) aluminium ring with four screws, 920 × 920 pixels, transparent in the middle and outside. Its opening (radius 370 pixels) sits just outside the face's outer circle, so no part of the scale is covered. Add it as an Image gauge (Add Gauge → Image) with no input, on top of the Axis gauge, and leave its Image Blend Color white (255, 255, 255) so the metal keeps its colours. At full size the face sits at 60, 60 inside the ring; if the gauge is scaled, make the ring 1.15 times the width of the face and keep the two centred.
Tested with dongle 1 (a generic ELM327) and RealDash, November 2026.
A plain ELM327 can read only one of these modules at a time. The TPMS, 4WD and ABS replies are all multi-frame, so the adapter has to send a flow-control frame to the module's own request ID (ATFCSH), and the ABS also needs its reply ID set with ATCRA661. An ELM327 holds only one flow-control header and one receive address, so a session set up for one module cannot read the others. Use one file (or one Car Scanner start command) per module and switch between them.
Tried in RealDash, and none of them worked:
- AT commands (
atfcsh798,atfcsh772,atfcsh261) in the<rotation>, one before each module's requests, as bare commands or with a name and conversion: the file did not run at all. - Several AT commands in one
headerattribute, separated by carriage returns ( ): no data. - Three RealDash connections, one file per module, through the same adapter: only the last connection in the list received data, because each connection's init overwrites the adapter's settings.
STN-based adapters (OBDLink). Untested. An OBDLink adapter (STN chip) can hold several flow-control address pairs and receive filters at once, so one RealDash file should be able to read all three modules. From the OBDLink Family Reference and Programming Manual (revision F): STFFCA adds a flow-control filter (frames from that ID are treated as multi-frame replies; adding one turns off automatic filtering), and STCFCPA adds a flow-control address pair (when a first frame arrives from the second ID, the flow-control frame is sent on the first). Init lines, after the 0100 and 0120 checks and without the ATFCSH, ATFCSD and ATFCSM lines:
<command send="stffcc"></command> <command send="stffca 7a8,7ff"></command> <command send="stffca 782,7ff"></command> <command send="stffca 661,7ff"></command> <command send="stcfcpc"></command> <command send="stcfcpa 798,7a8"></command> <command send="stcfcpa 772,782"></command> <command send="stcfcpa 261,661"></command>
The rotation then uses the TPMS, 4WD and ABS inputs above unchanged, each with its own header="atsh…". A plain ELM327 rejects the ST commands. Older copies of the STN manual use the names STCAFCP and STFAP, which are now deprecated.
Other modules found by a full scan
A full health-check scan with a Launch X431 CRP919, captured with PCAN-View on the OBD socket, shows 12 modules answering on the DLC. Every module that replied is listed here. The reply ID is not always the request ID plus 8. Current names and request details for each module are kept on ECU diagnostic CAN addresses.
| Request | Reply | Protocol | Identification replies | Module | How identified |
| 0x7E0 | 0x7E8 | KWP | 33980-78R0, 33980-78RC* | ECM | Standard engine address |
| 0x261 | 0x661 | KWP | 56100-77RA, 56100-78RF* | ABS / ESP | Only brake module left by elimination; SZ Viewer reads it under its ABS/ESP tab, and a driving capture shows wheel speeds, yaw rate and brake pressure in its data |
| 0x263 | 0x663 | KWP | 38720-77R0, 38720-77R0* | EPS controller | Parts catalogue |
| 0x271 | 0x671 | KWP | 36775-77R0, 36775-77RC* | Body control module | Parts catalogue |
| 0x274 | 0x674 | KWP | 34100-78R0, 34110-78RD* | Instrument cluster | Rev counter sweep test |
| 0x798 | 0x7A8 | KWP | 37160-61M0, 37120-78R0* | TPMS controller | Label and parts catalogue |
| 0x79A | 0x7AA | KWP | 37210-74PA, 37210-74PE* | Lighting and turn switch | Parts catalogue |
| 0x778 | 0x788 | KWP | 33990-52R0, 33990-78R8* | Dual sensor brake support | Parts catalogue |
| 0x793 | 0x7A3 | UDS | 38910-77R0, 38910-78RC* | Airbag (SRS) controller | Parts catalogue |
| 0x772 | 0x782 | UDS | 38885-77R0, 38885-78R0* | 4WD shift controller | Parts catalogue |
| 0x799 | 0x7A9 | UDS | 38960-78RA, 38960-78RA* | E-call controller | Parts catalogue |
| 0x751 | 0x761 | UDS | 33580-79R0, 33580-78R0* | Central gateway | Label and parts catalogue |
Reply ID offsets: engine +0x08; 0x261 to 0x274 +0x400; all others +0x10.
- KWP-style modules answer
1A 8Eand1A 8A(identification) and18 00 FF 00(DTCs). UDS-style modules answer22 F1 01and22 F1 88(identification) and19 02 FF(DTCs). - Requests to 0x273 and 0x262 (tester present) got no reply, so those modules are probably not fitted.
- 0x261 (ABS/ESP) is not confirmed by a part label, but its live data (wheel speeds, yaw rate, brake pressure) leaves no real doubt. All the others come from the parts catalogue, a label, or a test.
- The E-call controller (0x799) returned a stored code record (
92 4E 00, status 02) that the Launch report does not list. Its meaning is not known.
Instrument cluster output test (0x274 / 0x674)
A rev counter sweep commanded by the Launch X431 appears as a single KWP output-control request, after which the cluster sweeps the needle up and down by itself:
| Request | Reply | Notes |
3E 00 |
7E |
Tester present, about every 2.15 s |
30 01 07 80 40 00 00 |
70 01 07 |
Starts the sweep (service 0x30, local ID 01, "short-term adjustment") |
30 01 07 80 00 00 00 |
7F 30 22 |
Refused ("conditions not correct"); possibly a stop request sent after the sweep had finished |
The meaning of the four control bytes (80 40 00 00) is not known.
Open Questions
- The meaning of the status values at byte +8 (
49,4A,4C,82) and of the status bits in byte +4. - Bytes 76-79: whether they are the pressure at which the warning clears. A capture while the lamp goes out after reinflating would show it.
- Bytes 93-101, which change slowly (bytes 94-95 seem to follow the tyre temperatures or the warning state).
- More gauge readings at low and high pressure (the lowest calibration point is 0.027 bar off).
- Whether the central gateway forwards the request to the TPMS controller or remaps the address.
- Why Torque Pro stops after the first line of the reply (the adapter is ruled out).
- The meaning of the control bytes (80 40 00 00) in the instrument cluster sweep command.
- The meaning of the stored code from the E-call controller.
Sources
- Owner PCAN-View captures, October 2026.
- Owner PCAN-View captures of the SZ Viewer app (TPMS tab) with matching screenshots, 14 November 2026. Full decode on ECU diagnostic CAN addresses.
- Owner PCAN-View capture of the SZ Viewer TPMS tab with a matching Android screen recording (left front tyre let down until the lamp came on, then a 7-minute drive), 15 November 2026.
- Forum thread "Jimny JB74 (2019+) - Torque Pro PID for TPMS".
- BigJimny forum thread "JB74 OBD2 connection" (December 2020).
- Suzuki Jimny parts catalogue 9900B-40312-004 (type 1, October 2021), figures 350A, 351A and 351B.
- Suzuki Jimny JB74 workshop manual (owner's copy), wiring information, checked by visual inspection on the test car.
- RealDash-extras OBD2 documentation (OBD2 XML description file).
- OBD Solutions, OBDLink Family Reference and Programming Manual (FRPM), revision F.
- Car Scanner ELM OBD2 custom PID documentation.
