Support this project: The information on this page is free, but it took a lot of work to gather, test and write up. If it has been useful to you, you can say thanks with a donation at buymeacoffee.com/bigjimny.
Suzuki Jimny JB74 - CAN bus devices and the commands they answer
Status: work in progress. This page lists every module that answered on the OBD socket (DLC) of one RHD UK-market 2021 Jimny, its request and reply CAN IDs, and the diagnostic commands seen so far. Many sections are short because only identification and fault-code requests have been captured. See OBD2 Diagnostics reading project for how the captures were made and for the TPMS data in detail.
How to read this page
- All IDs are 11-bit CAN IDs on the OBD socket (pins 6 and 14, 500 kbit/s). The "request ID" is the header a tool sends to; the "reply ID" is where the module answers.
- Commands are shown as the payload bytes in hex, without the ISO-TP length byte. Replies longer than 7 bytes are sent as several frames; the tables show them reassembled.
- KWP-style modules use services such as
1A(read ECU identification) and18(read DTCs by status). UDS-style modules use22(read data by identifier) and19(read DTCs). - The reply ID is not always the request ID plus 8: the engine is +0x08, the 0x261 to 0x274 group is +0x400, and all others are +0x10.
- Identification strings are ASCII Suzuki part numbers. The first one in each module (
1A 8Eor22 F1 01) has no trailing character; the second (1A 8Aor22 F1 88) ends in*. They do not always equal the number printed on the module's label. - Commands marked captured were seen in a trace. Nothing here has been sent to a module by us except the TPMS requests.
Device table
| Request ID | Reply ID | Style | Module | Identification reply (first / second) | How the module was identified |
| 0x7E0 | 0x7E8 | KWP | ECM | 33980-78R0 / 33980-78RC* | Standard engine address |
| 0x261 | 0x661 | KWP | ABS (inferred) | 56100-77RA / 56100-78RF* | Only brake module left by elimination |
| 0x263 | 0x663 | KWP | EPS controller | 38720-77R0 / 38720-77R0* | Parts catalogue (38720-77R01) |
| 0x271 | 0x671 | KWP | Body control module | 36775-77R0 / 36775-77RC* | Parts catalogue (36775-77RC2 to RC4) |
| 0x274 | 0x674 | KWP | Instrument cluster | 34100-78R0 / 34110-78RD* | Rev counter sweep test |
| 0x798 | 0x7A8 | KWP | TPMS controller | 37160-61M0 / 37120-78R0* | Label (Model No. P61M0) and parts catalogue |
| 0x79A | 0x7AA | KWP | Combination switch (lighting and turn) | 37210-74PA / 37210-74PE* | Parts catalogue (37210-74PE2) |
| 0x778 | 0x788 | KWP | Dual sensor brake support (inferred) | 33990-52R0 / 33990-78R8* | By elimination |
| 0x793 | 0x7A3 | UDS | Airbag (SRS) controller | 38910-77R0 / 38910-78RC* | Parts catalogue (38910-78RC0) |
| 0x772 | 0x782 | UDS | 4WD shift controller | 38885-77R0 / 38885-78R0* | Parts catalogue (38885-78R01) |
| 0x799 | 0x7A9 | UDS | E-call controller | 38960-78RA / 38960-78RA* | Parts catalogue (38960-78RA0, RA1) |
| 0x751 | 0x761 | UDS | Central gateway | 33580-79R0 / 33580-78R0* | Label (33580-79R01) and parts catalogue |
Two more addresses, 0x273 and 0x262, were probed by the scan tool and did not answer.
The names marked "inferred" are guesses from elimination and part-number series, not confirmed by a label or test.
0x7E0 ECM
Models: JB74 (2018+, tested on 2021) — untested on: JB64, JC74, JB43
Request 0x7E0, reply 0x7E8. This is the standard OBD engine address, so standard mode 01 PIDs should be available here, but none were captured.
| Request | Reply | Meaning |
3E |
7E |
Tester present (captured) |
1A 8E |
5A 8E + ASCII 33980-78R0 |
ECU identification (captured) |
1A 8A |
5A 8A + ASCII 33980-78RC* |
18 00 FF 00 |
58 00 |
Read DTCs by status: none stored (captured) |
0x261 ABS (inferred)
Request 0x261, reply 0x661. The name is inferred: this is the only brake module left in the scan report after the others were matched, and 56100 looks like a brake part-number series. Not confirmed.
3E |
7E |
1A 8E |
5A 8E + ASCII 56100-77RA |
1A 8A |
5A 8A + ASCII 56100-78RF* |
18 00 FF 00 |
58 00 |
DTCs: none stored (captured) |
0x263 EPS controller
Request 0x263, reply 0x663. Matches parts catalogue entry 38720-77R01 (EPS controller).
3E |
7E |
1A 8E |
5A 8E + ASCII 38720-77R0 |
1A 8A |
5A 8A + ASCII 38720-77R0* |
18 00 FF 00 |
58 00 |
0x271 Body control module
Request 0x271, reply 0x671. Matches parts catalogue entries 36775-77RC2 to RC4 (body control module, RHD).
3E |
7E |
1A 8E |
5A 8E + ASCII 36775-77R0 |
1A 8A |
5A 8A + ASCII 36775-77RC* |
18 00 FF 00 |
58 00 |
0x274 Instrument cluster
Request 0x274, reply 0x674. Confirmed by the rev counter sweep test.
3E or 3E 00 |
7E |
Tester present, about every 2.15 s during the sweep test (captured) |
1A 8E |
5A 8E + ASCII 34100-78R0 |
1A 8A |
5A 8A + ASCII 34110-78RD* (last byte of the reply is 06) |
18 00 FF 00 |
58 00 |
30 01 07 80 40 00 00 |
70 01 07 |
Starts the rev counter sweep (service 0x30, local ID 01, "short-term adjustment"). The cluster then sweeps up and down by itself (captured) |
30 01 07 80 00 00 00 |
7F 30 22 |
Refused ("conditions not correct"). Possibly a stop request sent after the sweep had finished (captured) |
The meaning of the four control bytes (80 40 00 00) is not known. Other output tests (gauges, warning lights) have not been captured.
0x798 TPMS controller
Request 0x798, reply 0x7A8. The label on the module reads 37160-78R00, "BASE ASSY-TPMS", Model No. P61M0 (Continental A2C13930301, 433.92 MHz). The full data layout, calibration and app setups are on OBD2 Diagnostics reading project.
3E |
7E |
1A 8E |
5A 8E + ASCII 37160-61M0 |
ECU identification; matches Model No. P61M0 on the label (captured) |
1A 8A |
5A 8A + ASCII 37120-78R0* |
18 00 FF 00 |
58 00 (no codes) or 58 01 9A 31 20 (one code) |
DTCs by status. The code 9A 31 is probably the left front low pressure warning (inferred). The status byte was 20 in the full scan and E0 in earlier captures (captured)
21 00 |
61 00 + 100 bytes |
Sensor data block: four sensor records with ID, temperature-like value and pressure. The scan tool repeats it about twice a second (captured, decoded) |
ELM327 setup that works for 21 00: ATSH798, ATS0, ATL0, ATFCSH798, ATFCSD300000, ATFCSM1, then 2100.
0x79A Combination switch (lighting and turn)
Request 0x79A, reply 0x7AA. Matches parts catalogue entry 37210-74PE2 (switch assembly, lighting and turn, RHD).
3E |
7E |
1A 8E |
5A 8E + ASCII 37210-74PA |
1A 8A |
5A 8A + ASCII 37210-74PE* |
18 00 FF 00 |
58 00 |
0x778 Dual sensor brake support (inferred)
Request 0x778, reply 0x788. The name is inferred by elimination (the scan report's last unassigned module). Not confirmed.
3E |
7E |
1A 8E |
5A 8E + ASCII 33990-52R0 |
1A 8A |
5A 8A + ASCII 33990-78R8* |
18 00 FF 00 |
58 00 |
0x793 Airbag (SRS) controller
Request 0x793, reply 0x7A3. Matches parts catalogue entry 38910-78RC0 (airbag controller, VAN).
3E 00 |
7E 00 |
22 F1 01 |
62 F1 01 + ASCII 38910-77R0 |
Identification (captured) |
22 F1 88 |
62 F1 88 + ASCII 38910-78RC* |
19 02 FF |
59 02 4B |
DTCs by status mask: none stored (captured) |
0x772 4WD shift controller
Request 0x772, reply 0x782. Matches parts catalogue entry 38885-78R01 (4WD shift controller).
3E |
7F 3E 13 |
Refused: incorrect message length. Sent four times by the scan tool (captured) |
3E 01 |
7F 3E 12 |
Refused: sub-function not supported. Sent four times (captured) |
3E 00 |
7E 00 |
22 F1 01 |
62 F1 01 + ASCII 38885-77R0 |
22 F1 88 |
62 F1 88 + ASCII 38885-78R0* |
19 02 FF |
59 02 4B |
The scan tool tried the KWP-style 3E first and fell back to the UDS form 3E 00.
0x799 E-call controller
Request 0x799, reply 0x7A9. Matches parts catalogue entries 38960-78RA0 and RA1 (E-call controller).
3E |
7F 3E 13 |
Refused: incorrect message length. Sent four times (captured) |
3E 01 |
7F 3E 12 |
3E 00 |
7E 00 |
22 F1 01 |
62 F1 01 + ASCII 38960-78RA |
22 F1 88 |
62 F1 88 + ASCII 38960-78RA* |
19 02 FF |
59 02 4B 92 4E 00 02 |
One stored code record: 92 4E 00, status 02. The Launch report does not list it and its meaning is not known (captured)
0x751 Central gateway
Request 0x751, reply 0x761. The label on the module reads 33580-79R01.
3E 00 |
7E 00 |
22 F1 01 |
62 F1 01 + ASCII 33580-79R0 |
22 F1 88 |
62 F1 88 + ASCII 33580-78R0* |
19 02 FF |
59 02 4B |
The gateway sits between the OBD socket and the vehicle CAN bus. Whether it forwards requests to the other modules unchanged is not confirmed.
Addresses probed with no reply
The scan tool sent tester-present (3E) about eight times each to 0x273 and 0x262 and received nothing from the expected reply IDs (0x673 and 0x662). They are probably modules this car does not have, such as an automatic transmission or auto-levelling controller. This is a guess.
ELM327 notes
- Only
0x798has been tested with an ELM327. For other modules, setATSHto the request ID andATFCSHto the same ID, and you may needATCRAwith the reply ID, because the reply is not always the request ID plus 8. This is untested. - Replies from the 0x7xx modules are multi-frame for the identification strings, so the flow-control settings from the TPMS section probably apply there too. Untested.
- Do not send output-control commands (service
30and similar) from a head-unit app while driving.
Sources
- Owner PCAN-View captures of a Launch X431 CRP919 full health-check scan and rev counter sweep test, October 2026.
- Suzuki Jimny parts catalogue 9900B-40312-004 (type 1, October 2021), figures 350A, 351A and 351B.
- Labels on the TPMS controller and central gateway of the test car.
