Rear Wheel Bearings
Changing the bearings
Removing the hub
Removing the shoes
NO PICTURE.
You then need to remove the brake pipes from the cylinder. Undo the pipes and catch the drips of brake fluid. There is one pipe if you are doing the passenger side and two pipes if you are doing the drivers side.
Removing the Hub
PICTURE REQUIRED
The hub can now be removed. The unit is a friction fit into the axle casing. Attach a slide hammer to the hub and pull it out by using the slide hammer action. Alternatively refit the wheel or old wheel or brake drum (backwards) and hit the hub from behind to drive it off.
Removing the Bearing
The damage to mine is clear!
This is what a new bearing should look like. Note that it has a built in "spacer" on one edge, this should be to the OUTSIDE of the hub/wheel.
New bearing kits are available in the BigJimny store. There is also a special kit for ABS equipped cars
Dismantling the Hub
This is the tool, it is available from the BigJimny Store. Make sure that the tool and the nut are completely clean as the tool will not fit. Make sure the tool is inserted into the nut correctly with the pins all in the holes in the nut, you are really going to have to swing on the nut to release it. I had to use a long breaker bar AND a piece of scaffold tube. With the nut removed the hub should be removeable, it might need a pull with a slide hammer, mine just pulled off by hand.
With the hub face down on a surface you can now remove the bearing seal from the rear of the hub. I prised mine out with a screwdriver.
Then you can use a pair of long nose pliers to remove the C-Clips that retain the bearing, note that these may be corroded in and difficult to even see at first.
Now comes the first bit that is supposed to be difficult. Suzuki say that the bearing needs to be removed using a press. I decided to have a go myself. Using an old piece of bearing and a steel pin I hammered out the bearing and it only took two or three swift blows. The picture shows the steel pin resting on the bearing before being hit. Note the use of the brake disk to provide a holder for the hub allowing the bearing to be driven out of the bottom.
The bearings are Koyo brand as standard. The BigJimny store has a kit available which includes the seal and the c-clips (not all kits contain the c-clips), the Wheel Bearing Kit is here
The rebuild
Suzuki says the new bearing needs to be pressed into place. I decided to try a bit of school boy physics. I coated the bearing in Copper Grease and then put it in the deep freeze overnight.
The hub was placed in the oven at 180 degrees for 30 minutes. So with an ice cold bearing and a very hot hub I put the bearing in the hub, placed the old bearing ring and the steel pin on top and tapped the bearing straight into place. It took two gentle hits!. Again note the use of the brake disk to hold the hub.
ALLOW THE WHOLE ASSEMBLY TO COOL BEFORE TOUCHING OR TURNING THE BEARING ASSEMBLY
Once it is cooled put grease into the ends of the bearing. Then insert the new circlip and the oil seal. I found that the oil seal pressed in ok by hand once coated in Copper Grease. The oil seal has a protruding lip,this must be to the outside of the joint. Grease the inside of the bearing and slide the hub back onto the driveshaft
Grease the hub nut and tighten the nut using the special tool, torque it to 220NM or 160ft lbs – ie. really tight!.
Use a punch to bend the inner lip of the nut to lock it in place. Refit the hub thrust washer and circlip to the driveshaft.
Page last edited on 29/07/2016 by user Mlines
