Revision as of 18:50, 20 January 2017 by Mlines (talk | contribs) (→Introduction)
4WD transmission failure diagnostics
File:Locking Hubs.png
Overview of locking hubs
As stated, the diagrams are highly simplified and there are a few key points to remember:
  1. The vacuum makes the collar slide, but then is NOT required in order to hold the collar in position. Once the collar has slid in either direction it will stay there through the use of magnets and friction.
  2. The vacuum is used to make it slide both locked and unlocked by changing the route of the vacuum, removing the vacuum tube from a locked hub will not unlock it.
Note:
This guide was written based on a RHD (right hand drive) petrol Jimny configuration. The situation in LHD petrol Jimnys might differ in the positioning of some elements. The vacuum system in diesel (DDiS) Jimnys differs significantly in some aspects (see wiki article "Diesel (DDiS) Jimny specifics‎‎" for more information).
1.
2.
[PICTURE 2]
Figure 1. Location of Vacuum System
3.
[PICTURE 3]
Figure 2. Vacuum Check Valve
4.
[PICTURE 4]
Figure 3. Valve block
5.
[PICTURE 5]
Figure 4. Vacuum Tank
6.
[PICTURE 6]
Figure 5. Vacuum Tubes
7.
8.
[PICTURE 7]
9.
10.
11.
[PICTURE 8]
Figure 6. Lock tube (with brake calliper removed)
[PICTURE 9]
Figure 7. Both lock and unlock tubes (black braided tubes) - the unlock tube is the lower tube that comes down to the front of the hub.
12.
[PICTURE 10]
Figure 8. Vacuum Tubes
13.
14.
Fault finding
15. The table below shows the typical faults:
[TABLE 1]
Checking the system
16.
  1. Put the handbrake on, put the gearbox in Neutral, start the engine.
  3. Put the transfer box in 4WD, listen for a loud click from the hub and try and turn the car wheel by hand. If the wheel turns then it has not locked.
  4. If it has locked then move the transfer box out of 4WD, listen for a loud click and try and turn the wheel by hand. If the wheel turns then it has unlocked ok.
  5. Repeat for other front wheel.
17.
Problem Area (i) – 4WD Switch has failed.
18.
Problem Area (ii) – Switch wiring has broken.
19.
Problem Area (iii) – Fuse has gone.
20.
[PICTURE 11]
Figure 9. Type 1/2 Fusebox – 4WD is FUSE 21
[PICTURE 12]
Figure 10. Type 3 Fusebox – 4WD is FUSE 38
Problem Area (iv) – 4WD controller has failed.
21.
22.
  4. Air conditioning?
  5. 0 volts (earth)
  6. Vacuum switch –Open circuit or earth depending on Vacuum switch
  8. Air conditioning??
  9. Tachometer??
  10. 12 volts (from fuse)
Problem Area (v). - Vacuum leaks from the system
Problem Area (vii). - Pressure switch failure
Problem Area (ix). - Vacuum pipes blocked
23.
24.
Problem Area (vi) – Solenoid has failed.
25.
26.
