- 1 Introduction
- 2 Regular maintenance
- 9 Driving (im)properly
- 10 Lending the vehicle
- 11 Overloading the vehicle
- 15 Proper tyre pressures
This article contains some important practical tips, notes and warnings when using and operating any Jimny.
They can:
- Ease your life,
Regular maintenance
All Jimnys have classic 4WD vehicle construction design, which requires simple but regular maintenance in order to keep them in optimal operating condition. That means regular changes of many fluids which the vehicle uses, as well as some filters and some other parts. Even more frequent regular maintenance is especially important if the vehicle is regularly used in difficult operating conditions.
Read the wiki article "Regular maintenance intervals and consumables" for full info about this topic.
- Then disengage.
Jimny 1-4 have a part-time 4WD transmission system without a center differential.
- Dry tarmac roads;
During this process, do not turn the steering wheel while being stationery. Turn it only while in motion.
Exception to this rule are vehicles where the hand brake actually brakes the gears in the gear box or in the transfer box, instead of the typical design where the hand brake brakes the discs or drums in the rear wheels.
Jimny 3 and 4 have the "typical" design. Some Jimnys 2 (SJ410 models specifically) have the transfer box hand brake, so they are an exception.
Explanation of the incompatibility:
Conclusions:
Here is a video of the sequence on a 2005 VVT Jimny 3:
A few main rules of defensive driving:
- Otherwise, brace yourself.
If you drive any Jimny like an ordinary modern vehicle:
For example, observe this compilation of crashes and accidents on roads in winter conditions, and imagine how would your Jimny fare in some of them:
Lending the vehicle
There are three risks:
- In the case of Jimny 3:
- Some comparative examples
- How?
- That's how.
- How?
An example:
Conclusion:
- Proceed with caution.
- Assess the situation!
If your Jimny has a fault due to which it has to be towed on a certain length of road, you must take special precautions in order to avoid critical damage to its transmission when towing it!
Аll information in this chapter has been written based upon Suzuki's official guidelines for towing a Jimny 3 as written in vehicle's official Owner's manual - section 7 about towing.
Tyre pressures on Jimny 3
Tyre pressures on Jimny 4
- Info needed ...
Page last edited on 23/07/2019 by user Bosanek
