Gearbox, Differential and Transfer Box Ratio Information
| Date | Country | Engine | Gearbox | Gear 1 | Gear 2 | Gear 3 | Gear 4 | Gear 5 | Transfer Box | High | Low | Final Drive |
| 1998 | UK/EU | G13B | Manual | 3.652 | 1.947 | 1.423 | 1.000 | 0.864 | Manual | 1.320 | 2.145 | 3.909 |
| 1998 | UK/EU | G13B | Auto | 2.962 | 1.515 | 1.000 | 0.738 | N/A | Manual | 1.320 | 2.145 | 4.090 |
| 2001 | UK/EU | M13A | Manual | 3.652? |
1.947? |
1.423? |
1.00 | 0.864? |
Manual | 1.32 | 2.145 | 3.909 |
| 2001 | UK/EU | M13A | Auto | 2.962? |
1.515? |
1.000? |
0.738? |
N/A | Manual | 1.32 | 2.145 | 4.090 |
| 2005+ | UK/EU | M13AVVT | Manual | 4.425 | 2.304 | 1.674 | 1.190 | 1.000 | Electric | 1.00 | 2.002 | 4.300 |
| 2005+ | UK/EU | M13AVVT | Auto | 2.875 | 1.568 | 1.000 | 0.695 | N/A | Electric | 1.32 | 2.643 | 4.090 |
| 2005+ | EU | K9K | Manual | 4.246 | 2.357 | 1.695 | 1.242 | 1.00 | Electric | 1.00 | 2.002 | 3.416 |
| 2000 | JP | K6A | Manual | 4.031 | 2.391 | 1.513 | 1.00 | 0.790 | Manual | 1.320 | 2.145 | 5.375 |
| 2000 | JP | K6A | Auto | 2.902 | 1.515 | 1.00 | 0.736 | N/A | Manual | 1.320 | 2.145 | 5.375 |
| 2010 | JP | K6A | Manual | 5.106 | 3.107 | 1.908 | 1.254 | 1.000 | Manual | 1.320 | 2.643 | 4.300 |
| 2010 | JP | K6A | Auto | 2.875 | 1.568 | 1.000 | 0.696 | N/A | Electric | 1.320 | 2.643 | 5.375 |
See below for some worked examples:
2005 VVT manual gearbox Jimny, engine at 4000 RPM and in 5th gear High Ratio, standard wheels
| Engine | Gearbox | Transfer Box | Diff | Wheel | |
| Input | -------- | 4000 RPM | 4000 RPM | 4000 RPM | 465 RPM |
| Ratio | -------- | 1.000 | 1.000 | 4.300 | 28" Tyre |
| Output | 4000 RPM | 4000 RPM | 4000 RPM | 465 RPM | 77.7 MPH |
2001 M13A manual gearbox Jimny, engine at 3000 RPM and in 1st gear Low Ratio, 30" Tyres
| Input | ------ | 3000 RPM | 821.4 RPM | 382.9 RPM | 97.97 RPM |
| Ratio | ------ | 3.652 | 2.145 | 3.909 | 30" Tyre |
| Output | 3000 RPM | 821.4 RPM | 382.9 RPM | 97.97 RPM | 8.7 MPH |
2001 M13A manual gearbox Jimny, engine at 3000 RPM and in 1st gear Low Ratio, 30" Tyres with Differential from later VVT
This shows an example of a modified diff with an increase reduction ratio
| Input | ------ | 3000 RPM | 821.4 RPM | 382.9 RPM | 89 RPM |
| Ratio | ------ | 3.652 | 2.145 | 4.3000 | 30" Tyre |
| Output | 3000 RPM | 821.4 RPM | 382.9 RPM | 89 RPM | 7.9 MPH |
Note: For the tyre/road speed calc you can use your maths from school or a web calculator - www.4qd.co.uk/road-speed-calculator/---- Page last edited on 24/02/2019 by user Bosanek
