- 1 Introduction
- 2 Solution with manually operated hub heads
- 3 Solution with fixed wheel hub heads
- 4 Converting from vacuum to manually operated front wheel hub heads
- 4.1 Introduction
- 4.2 Part 1: Installing fixed or manually operated hub heads
- 4.2.1 Introduction
- 4.2.2 Solution 1a - old manual hub heads from a Samurai or a Vitara
- 4.2.3 Solution 1b - aftermarket tailor-made Jimny manual hub heads
- 4.2.4 Solution 1c - fixed hub heads
- 4.2.5 Solution 1d - converting existing vacuum hub heads into fixed hub heads
- 4.2.6 Required tools
- 4.2.7 Practical notes
- 4.3 Part 2: Blocking or removing the vacuum system (valves, pipes)
- 4.4 Part 3: Fooling or removing the 4WD controller
- The purpose of this article is to provide you an alternative solution to repairing that system - replacing it altogether with manually operated free-wheeling front wheel hub heads.
- Even fixed front wheel hub heads can be installed (the procedure is almost the same) - this is also covered in this article.
The wiki article "Vacuum hubs - checking and testing" contains the following:
- The general introduction about the purpose and operation of free-wheeling wheel hub heads;
- Description of operating systems for free-wheeling wheel hub heads;
- All the details about vacuum operated free-wheeling wheel hub heads;
- Related issues and repair solutions.
Wheel hub heads / caps are usually just shortened in naming to "hubs", but a "hub" is actually an entire wheel hub assembly - the casing which contains the wheel bearing with its seals, the steering knuckle surround casing, the king pin bearings and (in the case of the Jimny) the pipes and passages which transport the air / vacuum through the wheel hub assembly to/from wheel hub heads.
Reasons and advantages
- However, there is luckily an alternative solution - to completely discard the vacuum system and vacuum front wheel hub heads, and install manually operated free wheeling front wheel hub heads (like in Samurais and other classic 4WD vehicles) or even fixed hub heads.
- Manually operated free wheel wheel hub heads generally have the lowest risk of failures, as there is by far the least amount of components which can fail.
- The modification is relatively simple to perform, with required parts widely available on the second hand market and/or in the aftermarket.
- If you just want to preventively minimize the risk of a failure;
- Also, manually operated front wheel hub heads indirectly allow the use of the "2WD-L" transmission mode, which Suzuki has not enabled by default in any Jimny.
Disadvantages
- As most manual free wheeling hub heads have no anti-tamper mechanisms, a malicious person can easily (dis)engage a hub head while the vehicle is parked (easily remedied by the driver when detected, but can cause confusion while driving in the meantime).
- If water enters into a manual free wheeling hub head, it can freeze the manual (un)locking spring mechanism in the hub head during frigid weather. If this happens while the hub head is disengaged, it can prevent the vehicle from using 4WD transmission when it is needed the most.
- It is also possible to install fixed hub heads.
- One possible source of obtaining fixed hub heads would be from a vehicle junkyard which has a dead "el cheapo" 2WD-only Jimny (quite rare, produced from 1998 to 2001).
- The other possible source would be from a SJ413 (Samurai) and from Vitara Mk1 (and possibly from Vitara Mk2 as well?), but it is not known if some additional spacers are required.
- The only difference in the end will be that you will never be able to disengage the front wheels from the drive line.
- They are theoretically more durable for extremely heavy-duty operation;
- There is an alternative unorthodox solution to modify Jimny's original vacuum-operated front wheel hub heads so that they become fixed (always engaged).
- The advantage of this solution is that no new (replacement) fixed hub heads are needed.
- It can be accomplished in a few ways.
- That topic is thoroughly discussed in this BigJimny forum topic.
This solution is less expensive of the two solutions with manually operated free wheeling hub heads, but involves more "fiddling" around.
Required parts:
- A pair of manually operated, second hand hub heads from a Suzuki SJ413 (Samurai) or from a Suzuki Vitara (Escudo / Sidekick / GeoTracker) Mk1.
- The cones from the SJ / Vitara hub head bolts;
- Since the hub heads from earlier Suzuki vehicles do not fit directly on a Jimny, a pair of special spacers/adapters (with suitable bolts), which sit between these hub heads and the wheel hub assembly, is also required.
- Reason: The vacuum sealing ring on the Jimny hub nut stops the SJ hubs from fitting. You could simply undo the hub nut and grind off the sealing ring. However, for this you will need a special tool to undo the hub nut.
There are numerous versions and editions of Suzuki SJ413s, Samurais and Vitaras in existence.
- Browse the shops like BigJimny, JimnyBits, Bits4Vits, etc. for suitable spacers/adapters (or for the special tool if you are a "headlong" type!).
- If you decide for the spacer rings, BigJimny sells a kit to sort out this problem.
Installation guide
This solution is more expensive of the two solutions with manually operated free wheeling hub heads, but is the most elegant of all.
Required parts:
- These are a direct "bolt-on" replacement - no spacers/adapters needed!
- The described procedure from solution 1a can be generally applied here as well, except that it is much simpler here - no issues with any bolts.
Required parts:
- Therefore, it is the cheapest of all solutions.
- It just needs some ingenuity and mechanical (or welding) skills in order to convert the hubs.
Beware that, in general case, the strength / robustness of modified (fixated) vacuum hub heads can never match the strength of true fixed hub heads, no matter which method to modify them was utilized.
Required tools
Required tools in any case are:
- For solution 1d, a welding machine or some other mechanical tools might be required.
Practical notes
- It has also been reported that manual or fixed hub heads from a Suzuki SJ410 / SJ413 / Samurai can allegedly be installed on a Jimny without any spacers.
- The prerequisite is that Jimny's "vacuum tight" hub nut is removed and a corresponding hub nut from the donor SJxxx vehicle is installed in its place.
- This also removes the need to use the special Jimny hub nut unlocking tool when changing a wheel bearing afterwards.
Reasons
Possible solutions
- At the valves in the engine bey - disconnecting the pipes from the valves and then blocking both the pipes and the valves.
Disadvantages and constraints
- Vacuum metering valve;
- The check valve;
- Reason for the short circuit: This valve used to short-circuit this connector whenever it sensed a successful vacuum formation. By permanently shorting the wires, the 4WD controller will always believe that the vacuum system is working fine. A permanent short circuit condition should not harm it (theoretically).
- This will "free" the vehicle of all electronic / smart / modern / vulnerable elements of the 4WD transmission system. It will be as classic as a Willys Jeep.
Disclaimer
- THEORETICALLY, if you have an ABS-equipped vehicle, and you unplug the module and connect blue/black and blue cables, the ABS controller should receive exactly the same reading as before (it's the same blue cable, it gets the same nominal 13V current).
Page last edited on 17/01/2018 by user Bosanek
