- 1 Introduction
- 2 Engaging and disengaging 4WD-H and 4WD-L
- 3 Using 4WD-H or 4WD-L on hard surfaces
- 4 Negotiating hairpin bends in 4WD modes
- 5 Using the hand brake in 4WD modes
- 6 Using 2WD / 4WD-H / 4WD-L buttons
- 7 Driving (im)properly
- 8 Lending the vehicle
- 9 Overloading the vehicle
- 10 Transporting driver + four passengers
- 11 Towing or recovering heavier vehicles
- 12 Towing a Jimny by another vehicle
- 13 Proper tyre pressures
This article contains some important practical tips, notes and warnings when using and operating a Jimny.
They can:
- Ease your life,
- You probably know that, in a Jimny, you can (dis)engage between 2WD and 4WD-H on the move (and with the steering wheel pointing straight).
- You might have also witnessed a loud "bang" from the front wheel vacuum locking hubs when disengaging, or even from a transfer case (that's already a serious bang!).
- Then disengage.
Jimny has a part-time 4WD transmission system without a center differential.
- Dry tarmac roads;
Many people make a mistake of thinking that wet tarmac roads are slippery and turn on 4WD. Well they are slippery, but not nearly enough for Jimny's 4WD system.
During this process, do not turn the steering wheel while being stationery. Turn it only while in motion.
Exception to this rule are vehicles where the hand brake actually brakes the gears in the gear box or in the transfer box, instead of the typical design where the hand brake brakes the discs or drums in the rear wheels.
Jimny (3rd generation, from year 1998) has the "typical" design.
Explanation of the incompatibility:
- Vehicles with part-time 4WD transmissions (like the Jimny) do not have a center (inter-axle) differential.
- For Jimnys, this is valid in both 4WD-H and 4WD-L transmission modes.
Conclusions:
- There is an annoying and potentially dangerous issue with some (early) Jimnys which have electrically ("push-button") controlled transmission (2005 - probably around 2008).
- The 4WD controller in later Jimnys (probably from around 2008 on) has a corrected design to acknowledge a transmission control button press only if the button is kept pressed for at least 2 seconds or so.
- In practice with those earlier Jimnys, it is very easy to accidentally (inadvertently) touch a 2WD or 4WD-H button when fiddling with the other nearby controls on the dash board, or when fiddling with your passenger.
- There is no known remedy for this issue on earlier push-button Jimnys, except that both the driver and the co-driver be very careful and aware of this.
- In fact there is an (expensive) remedy - replace its 4WD control computer with a 4WD control computer from a newer Jimny.
Here is a video of the sequence on a 2005 VVT Jimny:
- Do not drive the Jimny on the road as you would drive an ordinary passenger car.
- Drive the Jimny correctly and it might even be more entertaining than driving an ordinary vehicle.
- In fact, many motoring journalists commented that Jimny is very entertaining and joyful to drive when they test-drove the Jimny in the early 2000s!
- Now the new generation X of journalists spit on the same vehicle, just because they don't know how to drive it.
Driving Jimny properly means that you should drive defensively, especially in bends. Drive smoothly and observe ahead, so you can timely adjust for changing conditions.
A few main rules of defensive driving:
- Otherwise, brace yourself.
If you drive the Jimny like an ordinary modern vehicle:
- The way that idiot drove that Jimny in the video is actually how to drive a roadster-class vehicle on the road!
- Also bear in mind that Jimny, like most proper all-terrain vehicles, are significantly more susceptible (compared to "on-road" cars) to end up rolled over in collisions and collision evasion situations, and also in situations where vehicle starts to spin out of control (for example on a snowy or icy road).
For example, observe this compilation of crashes and accidents on roads in winter conditions, and imagine how would your Jimny fare in some of them:
Lending the vehicle
It is very dangerous to lend a Jimny to someone who is not trained to drive it. Read the chapter on proper driving for details why.
There are three risks:
- This is especially risky with early Jimnys (2005-2008) which have "push-button" transmission controls.
- Jimnys have unusually small weight carrying ability for a proper all-terrain vehicle - it is just around 330 kg in total.
- Jimny was made to transport four people at most, including the driver.
- Some comparative examples
- Forum user Bosanek indeed once transported four male adult passengers (with full mountaineering equipment) in his Jimny in an emergency situation for 80 kms, all on winding alpine tarmac roads.
- How?
- That's how.
- How?
- Jimny weights just slightly over one tonne, and Samurai is even lighter than that.
- Jimny with the Big Boys. Those goliaths can tow a bunch, 'and then some'. Jimny can't!
An example:
- A Suzuki Samurai tried to tow a Toyota 4Runner loaded with mountaineering equipment (cca 2000 kg total weight) up a relatively short, packed snowy uphill track.
- The Samurai had easily went up that section alone, and 4Runner managed to climb half way up several times.
- So Samurai started towing the 4Runner uphill.
- First the 4Runner lost the grip on the last 10 meters of the way, and almost immediately Samurai lost it as well.
- Samurai was pulled back, turned aside and then rolled over onto 4Runner's bonnet.
Conclusion:
- Jimny is relatively safe to use as a recovery vehicle for vehicles of similar weight (approximately up to 1500 kg).
- Proceed with caution.
- All these advices and cautions are valid when towing any vehicle (it does not matter if the towed vehicle has 4WD transmission or not).
- Assess the situation!
If your Jimny has a fault due to which it has to be towed on a certain length of road, you must take special precautions in order to avoid critical damage to its transmission when towing it!
Аll information in this chapter has been written based upon Suzuki's official guidelines for towing a Jimny as written in vehicle's official Owner's manual - section 7 about towing.
Page last edited on 22/01/2018 by user Bosanek
