Rebuild
- Range of impact sockets used to press in bearings
- 2 large flat head screw drivers
- a 2 leg gear puller and/or hydraulic press
- bearing seperator
- torque wrench(s) to cover 23-90Nm
- copper or plastic mallet
- sturdy metal tube of approx 25mm internal diameter, at least 130mm long; but see text for alternatives
Gearbox Removal
Dismantling
With the gearbox on your workbench, remove the 4 bolts holding on the gear change cover and remove. It's sealed with liquid gasket and may need a tap with a soft hammer.
