This article contains some important practical tips, notes and warnings when using and operating any Jimny.
They can:
- Ease your life,
Regular maintenance
Engaging and disengaging 4WD-H and 4WD-L
- Then disengage.
Using 4WD-H or 4WD-L on hard surfaces
Jimny 1-4 have a part-time 4WD transmission system without a center differential.
- Dry tarmac roads;
Negotiating hairpin bends in 4WD modes
During this process, do not turn the steering wheel while being stationery. Turn it only while in motion.
Using the hand brake in 4WD modes
Exception to this rule are vehicles where the hand brake actually brakes the gears in the gear box or in the transfer box, instead of the typical design where the hand brake brakes the discs or drums in the rear wheels.
Jimny 3 and 4 have the "typical" design. Some Jimnys 2 (SJ410 models specifically) have the transfer box hand brake, so they are an exception.
Explanation of the incompatibility:
Conclusions:
Using 5th gear in 4WD-L mode
Using 2WD / 4WD-H / 4WD-L buttons
Here is a video of the sequence on a 2005 VVT Jimny 3:
Driving (im)properly
A few main rules of defensive driving:
- Otherwise, brace yourself.
If you drive any Jimny like an ordinary modern vehicle:
A tipped Jimny 3 - how would you recover this?
A Jimny 3 which had only mildly tipped to its side
A Jimny 3 which has suffered a "proper" rollover
For example, observe this compilation of crashes and accidents on roads in winter conditions, and imagine how would your Jimny fare in some of them:
Lending the vehicle
There are three risks:
Overloading the vehicle
- In the case of Jimny 3:
Transporting driver + four passengers
- Some comparative examples
How to fit three people in the back of a tiny car
The "atmosphere" in a vehicle which is crammed with people
- How?
- That's how.
- How?
Towing or recovering heavier vehicles
Jimny 3 gives an impression that it can do Big Things ...
... until you align it properly with the Big Boys
An example:
Conclusion:
- Proceed with caution.
- Assess the situation!
Towing a Jimny by another vehicle
If your Jimny has a fault due to which it has to be towed on a certain length of road, you must take special precautions in order to avoid critical damage to its transmission when towing it!
Аll information in this chapter has been written based upon Suzuki's official guidelines for towing a Jimny 3 as written in vehicle's official Owner's manual - section 7 about towing.
Proper tyre pressures
Tyre pressures on Jimny 3
Tyre pressures on Jimny 4
