Re:Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
- lookonimages
- Thank you received: 64
- Thank you received: 479
- lookonimages
- Thank you received: 1761
- Thank you received: 77
Added some new wheels. A little bigger but looks so much better.
215/75r15 general grabber all terrains.
What's the impact on performance (acceleration/braking) and fuel consumption like?
- lookonimages
Just did the wheel change. Will be able to give feedback much later on consumption. Only did do a 10km drive yesterday and first impresion was acceleration feels like normal std tyres. Currently dont feel negative impact.
These tyres are only 1.5% bigger in diameter but width increases 10%.
They do look much more bigger and have AT profile that looks a little more aggressive.
One of the reasons behind these questions is many years ago I did something similar with a Suzuki Swift, I was almost 20% wider on the tires with a very minimal increase in diameter, the impact on acceleration was not noticeable, but it took a heck of a lot more brake to bring it to a stop, (because the bulk of the rotating weight was further away from the center of rotation) and this eventually lead to warped rotors, and a brake upgrade.
The Jimny, like that Swift uses a relatively small solid rotor, I've started compiling a list of parts to upgrade the Jimny front disks to a more substantial vented system, just in case the need arises.
- lookonimages
Currently I dont find any negatives in respect of braking. It feels like with std tyres.fordem wrote: Did you notice any difference in the way it stops? Maybe needs a little bit of a firmer push on the pedal, hopefully not too much firmer.
BUT
Short town trips so far with jimny was with no loads etc. Vehicle empty with only driver.
I might take it for a long drive maybe over the weekend and drive some passes in our area to get a more substantial feedback.
The other aspect is that I am not aggressive driver and not hard on braking, so if there are minimal impact on braking I might not notice simply because of my driving style.
On the other hand an aggressive driver might pick up difference easier.
For me currently they feel pretty much the same as std wheels
Average km/L for last 13000 km was 13.2 km/L
- Roger Fairclough
- Thank you received: 194
If you still like the idea of vented discs then Martin has covered this in one of his tutorials.
Roger
oger
Upgrading the brakes using Brembo vented rotors, large calipers & pads and braided stainless steel flex made a huge improvement, and yes, it was driven hard.
By the way - it's not the increase in tire diameter that causes the issue - it's the increase in rotating mass, and the fact that the rotating mass is concentrated at the outer edge, rather than being evenly distributed - I'm not theorizing here - proven on the street experience.
- Roger Fairclough
Roger
And the reason I am pointing this out is that on that particular vehicle, the wider tire/wheel assembly did not significantly increase either the diameter or the mass of the rotating assembly - it was a heavier tire on a lighter rim which essentially meant that the rotating mass was further away from the center of rotation.
