Spare wheel bike rack?
- bpnwainwright
- Visitor
I've fitted a Peruzzo Brennero 2 bike spare wheel rack to my 2020 Jimny without really considering how much weight the spare wheel mount/door hinges will take. I know it won't be as strong as a proper towbar rack but I wanted a quick fix that I can take on and off easily. Does anyone have any experience with this? I've tried it out with one bike, total weight approx. 20kg (see attached photo of Jimny dwarfed by bike) without problems but I didn't travel far. Ideally I'd want to be able to put two bikes on (30kg or so) and not worry I'm going to tear the rear wheel off when I hit a bump...
Thanks for your help!
Ben
- Roger Fairclough
- Thank you received: 194
Roger
I have a tyre mounted rack on my Gen 4 and haven't experienced any issues, but don't use it much, also my bike is very light. I know that the Gen 3's had an issue with the door buckling when using a tyre mounted carrier, but the Gen 4's rear door seems to be better constructed.bpnwainwright wrote: Hi all,
Ben
Tow-ball mounted is definitely a better option.Roger Fairclough wrote: Some years ago on the A74 in Scotland I saw the remnants of two bikes and the rear door mounted rack that had broken away from a Volvo estate car. That convinced me that this type of mounting is fundamentally flawed . You are better off with a tow ball mounted unit.
Roger
- Thank you received: 1761
- RumbleAndSway
- Premium Member
- Thank you received: 11
Can recommend the Buzz Rack Scorpion for those with a tow hitch www.roofbox.co.uk/scripts/rbvehsel4_tab....PdG1gLxoCCGIQAvD_BwE
- Thank you received: 552
SO does anyone pay any attention to this?
I believe it is vehicle stability related rather than towbar failure.
A three bike towbar mounted carrier and 3 bikes is likely to be over or close to the limit. Often looked at the motorbike versions, but pushing stability and the limit too much in my opinion.
Just saying they are not limitless, but at least you have an official figure which is more than you will find for the rear door on the Jimny
- GeorgeC
- Visitor
This rack carried the bicycles vertically, with the rear wheel located in the rack frame and the front wheel pointing up.
I will try to search later in the day for the post.
Edit: My serch for "bike" did not locate the desired post. It may have been in a Aus-Jimny-Facebook Page. However, the question has been asked and covered may times in the past and repeating the search for "bike" will produce satisfactory results!
- bpnwainwright
- Visitor
- Roger Fairclough
A possible alternative would be to remove the front wheel and position the rack, if possible ,to move the bike into a better position.
Roger
- Roger Fairclough
Roger
