4th Gens on bigger than stock tyres
- Thank you received: 1754
- Thank you received: 165
mlines wrote: Perhaps we should all run one of those phone GPS acceleration apps, such as "drag Racer" on Google play store.
Multiple runs that are then averaged and publish the results. Perhaps 0-50 and/or 30-50.
play.google.com/store/apps/details?id=com.milejko.dragracer
Then we can compare across Jimnys, the more we have the better the results
Yes a great idea. I have one on my iPhone called ‘Race Timer’. Which allows you to program a custom speed metric.
Personally I’d avoid anything starting from a standstill as it is high dependant on the driver and surface.
- Thank you received: 34
I know when the MTs are on the car but I just trundle along to my trails and then enjoy their benefits.
Day to day the stock tyres are better in all aspects on road and I'm glad I have them and swaping them over regularly gives you an appreciation for the difference.
Is on road performance affected by my off road tyres ? Yes, absolutely.
On road I run the MTs at 30+ psi and that helps but acceleration is affected. I think its likely you are feeling the effects of that extra rotating mass.
I've seen some owners buy light weight forged wheels with the lightest tyres to retain the original wheel tyre weight but get those offroad benefits and not heavily affect on road.
So hopefully its nothing mechanical (problems) and you're just attuned to your Jimny.
crash486 JB74W
- SANDU
- Visitor
I have a friend, owner of a 2020 Jimny.
we would like to install 33 tires on it. Actually, we already ordered Maxxis Creepy Crawlers 255/85R16, which are nearly 33x10-16.
We know that a guy in Australia have 33 tires and it works. Yes, we will have to trim a little, we have a +5cm suspension, so that should be ok for now.
the question is, what offset will we require for wheels to avoid any rub at suspension arms? I know that -
ET-25 will work, but I can’t find the information what is the minimum offset that works. -25 can be too wide as I understand.
thanks in advance.
- Roger Fairclough
- Thank you received: 193
So you want to install 33" tyres on your mates Gen.4.
Sounds interesting, but exactly what do you hope to achieve?
Roger
- Roger Fairclough
Tonka is standard with regards engine, transmission and tyres. Dry flattish road, no wind. Accelerate and get into top gear and begin to speed up. As I passed 40 I pushed the button and ditto as I passed 60. Average for 3 runs 11.5 seconds. Only one run for 50 -70 due to traffic but 18seconds.
On my LC, fitting 33" muds increased the 50 - 70 by about 50%.
Anyone want to try it?
Roger
ps. A quick look on the web and i couldn't find any performance figures.
Hello guys,
thanks in advance.
First of all, good luck with this project and I'm genuinely keen to see how it will look. I suspect mini Monster Truck.
That said, I think you'll need a lot of work. I'm not sure just trimming will be enough and a 5cm (2" lift) is not a lot. And of course if you are off roading and have flexy suspension, all of your lift will be lost under suspension compression anyhow.
I'd also guess this size will murder on road performance. I found a huge reduction in performance going to a 217/75R15 AT!
So I think you may want more power and torque as well as re-gearing. On that note, I hate to think what it'll do to your low 1st crawl speed. Will certainly need to re-gear everything I'd have thought.
For the record a 255/85R16 should be 33.1", for reference this is my Jimny on 215/75R15 (27.7") AT's. Rolled up next to it is a 33.10.50R15 for my Land Rover. This is only 32.5" tall. So a 255/85 will be over 1/2" taller again and only slightly less narrow!!!
Are Jimny axles/drivetrain strong enough for tyres of this size?
- SANDU
- Visitor
I know we need to re-gear the transfer box, we will do it with Protrack gears and this should work enough.
We also know that the +5cm suspension will not be enough for the 33" diameter tires, and we will have to trim the fenders, but I think we will handle this after we fit the tires.
Still, we are unsure which offset to chose for these wheels.
I want them to sit inline with fender flares, but in the same time, I want to be sure they will not rub anywhere on suspension at full flex. This is why I posted here, in the hope to find a suggestion
Ring and pinion, we will not remove yet, because, if the future will be good, this car may sit on portals after that. It depends on the final budget.
I know from Australia that we need to upgrade the propshafts. The halfshafts and CVs are strong enough for 33" tires, they say.
And one more, the rear diff will soon be an ARB airlocker, so one weak point less.
- Thank you received: 468
www.youtube.com/channel/UClku6Tqzh8MvUcoMCpl8gUA
The wheel bearings at one end are identical so the shaft diameter at this point is the same. The Diff Gears that the driveshafts plug into at the other end are the ones fitted to the Samurai, Vitara and X90.
