Broke my diff.
- Thank you received: 332
Is this common?
- Thank you received: 1759
- Thank you received: 252
Grey pick up Jimny
Lambert wrote: That's impressive. Diffs are usually quite reliable even with quite big tyres. Was there any evidence of prior wear in the pinion bearings or were you working it quite hard when it failed?
Both gear backlash and bearing clearances seem just fine from what I can see and feel. Way better than most Samurai or SJ diffs i have set up by just throwing them together more or less. and i had lockers and 31" inch tires in those, and they are just the same except for the ratio. Those were old ones from 1985 to 1988 though. nothing is like it used to be when it comes to cost and quality.
If I had a gear wheel breaking like this at work I would say there could have been something wrong with the material..
At the time I had my Suzuki trailer with approx 3-400kg total weight and took off from home in first gear.. Wet partly icy paved road.
I am very pleased with the power in it now and I must say I do like to floor it as well.. So it has probably been strained a bit.
And I did break my gearbox too last year.
j999pre wrote: I've a pair of vvt diffs
I am trying to source it in Norway first, but might just send you a PM if I can't find any..
No luck yet on the interwebs tonight.
- Thank you received: 225
So you were being a heavy footed vandal then?
Still I do not see why the diff broke now. There was no sound in it, there was very little debris in the oil except for the obvious three large teeth. The oil was not particularly sparkly and shiny from metal particles with only very small traces of shavings.
No obvious reason as to why it broke.
I haven't been smoking the tires either, if I thought it was possible i might done it though.
Anyways I got an axle from a 2012 car on the way. the complete axle will cost me approx 500£ freight and all. (this is Norway)
On the up side I will put an ARB in there now and get an extra pair of half shafts.
Now I can hear what a properly set up diff should sound like, and comparing the new one with the old, it seems the old one made a noise on take off, and had less bearing pteload, and too much backlash.. The noise I thought was the transfer case gearing as that was when I first noticed it, but now it is gone.
My noise was hard to describe, mostly first gear take off, more if going up hill or pulling the trailer.kirkynut wrote: My 2000 rear diff did the same with the pinion gear but not the whole tooth, so it drove ok still, just with noises every now and then.
Clearly at peak torque.
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
