Jimny following camber of the road
- paradox1001
- Visitor
It’s really appreciated
@lambert I’m near bedale in North Yorkshire.
- paradox1001
- Visitor
If one side has been fitted with shims and not the other
Will I have to take the whole thing apart to remove the shims or can it be done by just removing the king pins one at a time?
- Thank you received: 1761
- paradox1001
- Visitor
Where abouts are you?
Which section of exhaust are you replacing?
- paradox1001
- Visitor
I replaced my back box last week it was a bit of a jiggle to get on with the tow bar
Next time I’ll do the rubber nearest to the tailpipe first
Sent from my GT-I9505 using Tapatalk
- Thank you received: 584
paradox1001 wrote: @ facade cheers for that I’ll give it a try
The shims fit over the top kingpin (usually) and are fitted from the outside after the hub is assembled, by removing the kingpin and slipping the shim over the pin part.
An old mechanics dodge was to put an annealed copper washer in there, the copper spreads out under the load when fitting and then work hardens to give a rather unscientific preload. You might find a thick hard copper washer in there.
The shop sell a kit of different shims to adjust that preload spot-on.
Before you dismantle the car, it might not be the hubs, but I can't think of anything else if the rest of the steering and suspension is in good order.
- paradox1001
- Visitor
I’d say about three fingers to a hand depending on the road
I know any car will follow the camber of the road
I just think mines following it quicker/harder than it should.
- paradox1001
- Visitor
I’ve sorted it today hopefully
It was a seized slider on the calliper causing the lhs brake to drag.
I’ve fitted new sliders,boots and bolts along with new anti rattle pad clips to the lhs calliper.
Weather permitting I’ll do the other side tomorrow then see if I can get the damper bolts undone so I can fit the new ones.
- Max Headroom
- Banned
- Thank you received: 217
My sliders gave me an impression of warped discs - replaced the discs for nothing as they were almost new but noticed LH pads werent wearing at the same rate.
The sliders just seemed to be coated in old dry anti-seize grease. Once replaced, the shudder under braking has gone
- paradox1001
- Visitor
Copper grease rots the rubber seals and then you suffer water/dirt ingress
Which washes the grease away and they corrode and stick.
