Shock extenders question
- wilku
- Visitor
The next step will be of course getting a proper spring + shock lift and by then I will have these extenders tested and will be able to re-sell them.
Martin - I 'designed' (i.e. figured out the dimensions) the extenders myself, based on measurements of my own Jimny, and took the front as reference, so it should be fine. We'll see some time next week.
- Thank you received: 923
wilku wrote: //EDIT: found a bits4vits blog entry about rear spacers used on the front: www.bits4vits.co.uk/store/re-lifting-the-jimny/blog_246.html
I'll do it the same way.
Glad to be of assistance
mlines wrote: Knowing Dave at Bits4vits, I am sure his brackets are designed properly to fit.
Why thank you Sir
- 1066Boy
- Visitor
mounting points by 40 mm on full compression. No bad thing as my tyres will hit the arches anyway.
On full extension, I have increased the point between axle and chassis by 40mm giving me more travel (tyre from wheel arch)
I have +2" springs and +2" shocks. Add to this 40mm extensions, its 40mm that the axle can move at the point that the
shock attaches before the shock tops out. If this is wrong please explain.
Sure maybe I termed it wrong when I said more flex. More axle droop would of been more appropriate.
- TomDK
- Visitor
But yes, more downtravel on the cost of uptravel. With the risk of springs falling out if you're not using spring spacers, spring clamps or longer springs.
- 1066Boy
- Visitor
to escape.
- 1066Boy
- Visitor
1066Boy wrote: No just +2" springs, +2" shocks and shock relocation brackets.
I'm confused why you have fitted shock extenders to extended shocks with matched springs? Surely that increases the chance of the shock bottoming out or the spring dislocating?
- 1066Boy
- Visitor
bottomed them out yet. I have spring location clamps so that keeps them in place. I have gone the extender
route to gain more axle droop. Some of the places I go its very easy to get a wheel in the air and lose traction.
I miss having a centre locking diff and a rear air locker but don't want to modify little Jim that far as its only for fun.
1066Boy wrote: I think the Pro comp es1000 is actually a little more than 2" in reality. Have used them quite hard and never
If the shocks are longer that only exacerbates the issue. Axle droop is useless if there is no pressure pushing the wheel down. You are joking about the centre locking diff bit, right?
- wilku
- Visitor
Or did you mean an air locker that you can engage from inside?
