BigJimnyMeet 2024
really loud vibration with slight judder
- kelky7777
- Visitor
07 Dec 2016 02:30 #175365
by kelky7777
New to the forum so hi everyone.
This is my second Jimny, the first was a 2001
standard, 139k, and it had the same problem, vibration
but nothing like as bad as my new one. Now have a 2002
jimny on 104k, also standard, and as you can see in
the video I have really bad and loud vibration
changing through the gears. It had a new clutch fitted
before I bought it, and a new exhaust front section
and cat, also had a new gearbox mount. I've replaced
all the transmission oils, apparently the front diff
was almost empty, have checked and there are no leaks
since the fluid change.
The transmission also has a loud whine and a kind of
woo woo woo noise in all gears, from looking around
the forums regarding the vibration there are a few
comments suggesting that its normal but my last jimny
was nothing like as bad, I haven't been selecting 4wd,
don't think that's working as I get the flashing light
and with front jacked up the wheels are free spinning
even when in 4wd with engine running, I'll get around
to that problem later. So all driving has been in 2wd.
Any one know what could be causing this? My mechanic
drove the car and said he'd come across this with
transit vans and it was usually a bearing in the rear
diff, he checked the shaft linkages and said they were
fine though not sure how well he checked, I'll have a
look myself tomorrow.
really loud vibration with slight judder was created by kelky7777
- johna
- Visitor
07 Dec 2016 08:27 #175372
by johna
Replied by johna on topic really loud vibration with slight judder
I would say its in the front end, there is a problem with 4wd, fix that first, as its probably there.When the hubs get water in them they rust and every thing sticks, you could have one wheel locked and the other free.and if the drive shafts get bent then there is the vibration.
John
John
- kelky7777
- Visitor
07 Dec 2016 09:03 #175376
by kelky7777
Replied by kelky7777 on topic really loud vibration with slight judder
Hi John, cheers, I didn't think of that approach, I guess even if fixing the 4wd doesn't solve the vibration issue it's one job out of the way.
- ryank192
- Visitor
07 Dec 2016 19:10 #175396
by ryank192
Replied by ryank192 on topic really loud vibration with slight judder
I have the exactly the same problem its really annoying. The only way i can deal with it is by keeping the Rpm high.
- kelky7777
- Visitor
07 Dec 2016 19:25 #175402
by kelky7777
' I have the exactly the same problem its really annoying. The only way i can deal with it is by keeping the Rpm high. '
That's how I've been driving mine, problem is I end up driving in 2nd gear a lot. Have you tried any fixes yet?
- ryank192
- Visitor
07 Dec 2016 19:53 #175408
by ryank192
I haven't tried anything yet. Been keeping an eye out on here to see if anyone had the same problem.
- Ste372
- Visitor
07 Dec 2016 20:53 #175411
by Ste372
Replied by Ste372 on topic really loud vibration with slight judder
We've got same problem on ours. Jus bought it 2006 58k miles on it. Really bad vibration through the car at 1800-2500rpm only when in 4th and 5th gear.
Im changing all drivetrain fluids asap to rule them out, more for piece of mind. We've also got a leak on gearbox suspect it's something to do with the prop/seal
- kelky7777
- Visitor
24 Jun 2017 19:33 #182267
by kelky7777
It's been a while but thought I'd update. After driving with the problem for several months I decided to have another go at it and asked a mechanic I know to have a look and check gearbox mount, sure enough the gearbox mount, also known as rear engine mount, was broke. The slightly annoying thing was that it was the same mechanic that checked the car the first time and even though I'd mentioned the gearbox mount and all other mounts he somehow missed it.
What I find odd is the last 2 mots for this car, before I owned it, point to failure due to 2 rotten rear shocks and a broken gearbox mount, then a pass certificate a couple of days later, when I bought it first thing I did was replace 2 rotten rear shocks and now the gearbox mount, so I reckon it was like that for 2 years and 'somehow' still passed.
Anyway, fitted a new gearbox mount and the vibration problem has reduced by around 40 per cent. but still there, in fact no change changing to fourth but third gear is now much better.
For normal driving, like anywhere outside London, where normal acceleration is possible you wouldn't notice the problem much at all and motorway performance is very smooth at around 65 mph. Despite the problems I still enjoy driving it, I never got around to finding the problem with the vacuum system but fitting manual hubs anyway.
I'm looking for some manual locking hubs if anyone has a spare set I can buy?
- Gazzt
- Visitor
25 Jun 2017 07:23 - 25 Jun 2017 07:24 #182270
by Gazzt
Replied by Gazzt on topic really loud vibration with slight judder
Hi Kelky
Did you find out what the transmission whine and woo woo noise was, as mine does that, 2008 plate with 51000 miles
Gaz
Gaz
Last edit: 25 Jun 2017 07:24 by Gazzt. Reason: spelling correction
- kelky7777
- Visitor
25 Jun 2017 21:23 #182280
by kelky7777
Hi Gaz. I think just wear and tear on mine, though I gather from looking here and there that its common with jimnys
- Gazzt
- Visitor
26 Jun 2017 13:47 #182290
by Gazzt
Cheers Kelky
I was wondering if the wa..wa part of the whine might have gone since you fixed the gearbox mount as it might be a clue as to where to start looking on mine.
Gaz
Gaz
- 1066Boy
- Visitor
26 Jun 2017 16:42 #182298
by 1066Boy
Replied by 1066Boy on topic really loud vibration with slight judder
Mine does it in 4Low but not in any other setting?
Time to create page: 0.107 seconds
