BigJimnyMeet 2024
help with General Grabber AT2
- Thank you received: 210
03 Dec 2010 18:27 - 03 Dec 2010 21:14 #6993
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
help with General Grabber AT2 was created by dirtydogz
GENERAL GRABBER AT2'S 205/75/15 OR 215/75/15
HAS ANY MEMBER USED THESE TYRES? WOULD LIKE FEED BACK PLS
THANX.BAZ
THANX.BAZ
2002 JLX Soft Top
Last edit: 03 Dec 2010 21:14 by dirtydogz.
- Nelson83
- Visitor
04 Dec 2010 15:56 #7017
by Nelson83
Replied by Nelson83 on topic Re: help with General Grabber AT2
I've got them fitted to mine They were reasonably priced from my then tyre fitters in Frome, Somerset (H+B tyres) - for 5 fitted and balanced on alloys they came out cheaper than almost all internet suppliers. I've had them on for just over 2 years (about 20-25k) and the back ones are almost like new, the fronts are due for replacement as the outside edge has worn more than the inside edge - a job for the new year.
On road they're fine, no road noise and plenty of grip.In the brown stuff they're fine for light laning etc, not comp/ extreme. In the current snow, they handle fine.
Like i said, my fronts are due for replacement at the begining on the new year, and i'll be replacing like for like. I'll try and post a few pics of the how much tread is left when it gets light tomoz
04 Dec 2010 17:21 - 07 Dec 2010 17:28 #7027
by dirtydogz
Thank you
For the information on the genral tyres,had some on my old sj410, 30 year a go so i'm happy they are still a good tyre.
BAZ
2002 JLX Soft Top
Replied by dirtydogz on topic Re: help with General Grabber AT2
Thank you
BAZ
2002 JLX Soft Top
Last edit: 07 Dec 2010 17:28 by dirtydogz.
- DAVE T
- Visitor
04 Dec 2010 18:38 - 04 Dec 2010 18:39 #7035
by DAVE T
Replied by DAVE T on topic Re: help with General Grabber AT2
i have had AT2S on mine for 30,000 miles now and there still heaps of tread and i have been in some nasty places with these, there a great tyre.
Last edit: 04 Dec 2010 18:39 by DAVE T.
07 Dec 2010 18:47 #7177
by mcjimny
Replied by mcjimny on topic Re: help with General Grabber AT2
To echo other replies, i've had some on for over 2 years now and i don't think there's a better value tyre for the jimny. BFG's will go on forever but will be at least double the price of the grabbers. Unless you want/need a really aggressive tread pattern i think they suit the jimny perfectly, i know people who lunch them on pickups and bigger trucks but they suit the lighter jimny.
The only time they really struggle is in deeeeep mud where they fill up with mud and won't clean quick enough.
If i wasn't after an aggressive tyre next time i'd have a full set in an instant but slightly wider.
The following user(s) said Thank You: dirtydogz
- Thank you received: 79
29 Dec 2010 12:27 #8285
by Foxtrot
Replied by Foxtrot on topic Re: help with General Grabber AT2
Hi, did the Grabbers fit ok as they are slightly taller at 205/75/15? my Jimny is standard with Duellers and I'm thinking about changing them out soon for some AT's due to them coming to the end of their life.
You may be ok with the wear on your tyres as long as they fit the discription below:
The current British legal limit for car tread depth is 1.6mm (across 75% of the tyre). However, most tyre experts advise that you replace your tyres when the tread is less than 3mm.
Thanks
Thanks
- biggaz
- Visitor
29 Dec 2010 12:54 #8288
by biggaz
Replied by biggaz on topic Re: help with General Grabber AT2
id go for the 215's like i have for that little bit extra width.
29 Dec 2010 13:16 - 29 Dec 2010 13:17 #8291
by Foxtrot
Thanks, my jimny is standard with no lifts, would 215's fit ok?
Last edit: 29 Dec 2010 13:17 by Foxtrot.
- biggaz
- Visitor
29 Dec 2010 13:37 - 29 Dec 2010 13:38 #8292
by biggaz
Last edit: 29 Dec 2010 13:38 by biggaz.
29 Dec 2010 13:39 #8293
by Foxtrot
ooohh they are nice! thanks
29 Dec 2010 14:14 #8295
by dirtydogz
Sorry i went for 205/75/15 maxxis m/t 753 bravo from camskill,£53.30+p@p,fitted on ok.
2002 JLX Soft Top
Attachment DSCF1276.JPG not found
Attachment DSCF1278.JPG not found
2002 JLX Soft Top
- biggaz
- Visitor
29 Dec 2010 14:17 #8297
by biggaz
They look great dirtydogz, you will have to scrub that blue stuff off the writing though haha
great for that money aswell!
